EM TuningJMB Retrofits
Results 1 to 15 of 15
    Aug 2011
    12
    A4 2.5TDI QUATTRO 2000(W) AKN 150HP ENGINE BE CUSTOM TUNED
    New to the forum, i have a audi a4 2.5tdi quattro 150hp akn engine code (w) 2000
    Just wondering if this car can be custom tuned on a rolling road or does it need a chip soldering to the ecu?
    Thanks in advance
    Jul 2007
    London
    3,250
    If it has a EDC15 then it's flashable trough the OBD port. Early b5 with the AFN engine needed chip removal as they were 1 time only ! If you take off your ECU look at the connectors: if 2 large ones then it's flashable trough obd if 3 smaller ones then it's not !
    FOR SALE:
    diffas's Avatar
    Lahti, Finland
    131
    Add diffas on Facebook Visit diffas's Youtube Channel
    AFB/AKN have msa15 ecu instead edc15 and therefore soldering work needs to be done.
    Slow and smoking - A4 2.5TDi+ 220+kw
    Aug 2011
    12
    Custom tune
    Quote Originally Posted by diffas View Post
    Does that mean it cannot be custom tuned! with only a standard chip? Only i have a 3.0tdi turbo on it and bigger nozzles going on reason for custom tune as a normal chip will not be correct as far as i`m aware. I don`t know if the ecu is interchangable on these as AKE off a 2001 tdi 180 can be custom tuned i think.
    Jul 2007
    London
    3,250
    AKE does not work unless you replace the AKE pump and the dash + engine wiring loom. Few bits are different but they will swap over. Do you still want to sell the nozzles and the aditional bits ? Drop me a pm or give me a ring if you need to talk, interested in a few bits and bobs you have ! Regards,
    Chris- 07789912128.
    FOR SALE:
    Aug 2011
    12
    I was originally going to sell these parts as i blow the engine up due to oil feed burst and losing all oil, i am in process of getting another engine and starting again basically but don`t know about getting the custom tune side of things.
    Jul 2007
    London
    3,250
    Ok then, if you stll thinking of selling the bits then let me know... Good luck finding someone good enough to map the car for the hardware changes, you will experience iddle shudder from the race 683 nozzles and smoke before the turbo spool ! I have a remap by Celtic Tuning but not too happy to be honest and the above issues are still present. AKN ecu is not obd flashable...
    FOR SALE:
    Aug 2011
    12
    Sedoxperformance, have heard some good things about these for custom tune!!
    Aug 2011
    12
    Custom tune
    Quote Originally Posted by adamss24 View Post
    Just a thought....if i were to replace the ecu from a 2001/2002 audi a4 AKN 150hp model!! Would that work as far as custom tune is concerned for the car?
    Jul 2007
    London
    3,250
    You will need the ECU, dash + wiring loom and injector pump. You also need the ECU wiring loom and some bits are different as well. The b6/c5 AKE had a mild revision so it won't work with the old pump EDC + later pumps had an extra immobiliser built in which needs codding to the ECU... Easier to have a custom map modded with an emulator and your ECU socketed, that way you would limit trial and error.
    FOR SALE:
    diffas's Avatar
    Lahti, Finland
    131
    Quote Originally Posted by cready View Post
    It's still full custom tunable. You just need to do some little soldering to add chip sockets to your ecu. Then it takes few minutes to change software.
    Aug 2011
    12
    Custom tune
    There is a company who can do a custom chip to the standard ecu with the turbo and nozzle upgrade but don`t know how good of a job it will be!!
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Who are they? Maybe someone can vouch for them
    Aug 2011
    12
    Quote Originally Posted by Byzan Pics View Post
    Celtictuning
    Aug 2011
    12
    I have a chance of an AFB engine from year 2000 to fit my car....but the engine from mine is AKN, not sure if these engines are interchangable!!! Heard somewhere they are but dont know how true that is.
    Obviously both are 2.5tdi quattro`s but dont`t wont to swop it over and find it wont start
  1. headlight washer (a6 2.5tdi quattro, 2000 plate)
    By abdul h ghafoor in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th March 2012, 10:10
  2. Replies: 2
    Last Post: 28th February 2012, 10:52
  3. 1996 A6 2.5TDi Quattro Estate Glow Plug Problem
    By mmarks in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th May 2007, 20:13
  4. New 2.5TDi Quattro Tip =O)
    By TheTonsta in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th October 2003, 17:32
  5. A6 Avant 2.5tdi quattro sport Tiptronic
    By jyeoman in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 24th August 2003, 16:39
