EM TuningVolks Autos
Results 1 to 23 of 23
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    revs dropping when clutch dipped. strong fuel smell.
    Still have this fault :-( Car was fine before I got banned, put new battery in and since then it's done it. Everytime I stop or rev the car the revs bounce between 200rpm and normal idle it bounces about 3 or 4 times before settling at normal tickover. It often dies mid manouver which requires a restart and usually dies again as soon as I dip the clutch again. Parking etc is becoming a total pig. Car is also stinking of fuel drives with lurches on light throttle and even being very gentle I'm not getting 30mpg average.
    It was suggested I have an airleak but this has been ruled out after a thorough check of the entire boost and vacume system.
    Help as I'm close to torching the Damn thing and buying an Astra
    Life begins at 140mph
    www.passionford.com
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    MAF ???
    jcb
    Sep 2005
    uk
    4,077
    ^ this
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    Figures, was hoping it would be something else. LoL. Will have to sort one at the weekend.
    www.passionford.com
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Have you checked for codes?
    I had similar idle bounce and it was a dodgy tank vent valve.
    TD5 Land Rover Defender build
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    A friend of mine has VAG-Com and was supposed to have come over 4 times now to scan it for me. Unfortunately he has been worse than useless and let me down everytime.
    I really want to make sure it is the MAF before buying another as it looks like it's the fat end of £250 for a new Bosch one.
    Got the MOT on the 3rd Nov so need it sorting
    www.passionford.com
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    Right, mate scanned it for me last night an nothing, it was suggested the throttlebody be recalibrated. Did this and it still does it
    MOT in the morning so bit worried now Anybody know the part no for the MAF for a 96 car?
    ECP list three ranging from 80 to 260???
    www.passionford.com
    jcb
    Sep 2005
    uk
    4,077
    pull the maf
    i had no codes but it was fecked
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    The 96 car needs the expensive rare MAF. I have a spare old one here if you get stuck, but that won't help your MOT in the AM
    Quote Originally Posted by Oranoco View Post
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    Cheers mate. Loads of bits on my car are post 96 so I might get lucky. Will need to check number on my current one. Oh yeah... and cross my fingers.
    www.passionford.com
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    MAF is 96
    Found if I unplugged the MAF the fault remains. My brother seems convinced the fault is related to the Lambda sensor rather than the MAF. Any opinions before I spend
    www.passionford.com
    Jun 2012
    Ireland
    59
    i had kinda the same problem car was reving that would just cut out or press the clutch and it cuts of again unpluged MAF was same thing i used to show only 19 mpg scaned for fault codes maybe ten or more times and just the fault code apeared. turned out to be faulty MAF got it changed and drives like a dream again.
    jcb
    Sep 2005
    uk
    4,077
    if the fault remains after the MAF is not connected it has to be something else or something in addition to the MAF
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    Thanks JCB, that was the thinking of my brother and I.
    MAF number is 058 133 471 A
    www.passionford.com
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    Update
    Fitted new MAF at a cost of £200 and the car pulls like a train :-) But...... revs still drop when reved :-( , left the car in a mates garage with the battery off to reset ecu, will see what happens when I go and put the battery on again.
    www.passionford.com
    "Stick a V8 in it!"
    15,370
    My old FWD was doing something similar, and it was a faulty tank vent valve.
    You could try blanking it off (leave the tank side open to atmo, blank off the feed to the manifold/tip)
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    Where is it and how do I do it?
    New problem added now, pulls hard in 2nd gear change to third and boost won't go above about 5psi. Getting really annoyed now.
    Also noticed if I give it a rev when just started the revs drop to idle perfectly. By time I've gone 300m the fault is there. Also if I dip the clutch and coast the revs just bounce up and down without settling.
    www.passionford.com
    "Stick a V8 in it!"
    15,370
    The 5psi thing is limp mode, you should have a fault code for that?
    The tank vent valve sits on top of the airbox.
    Apr 2004
    12,520
    easiest way to check tank vent is to loosen the fuel cap, it will probably woosh and the idle will settle. Leave it just about done up and try that, see how it gets on
    "Stick a V8 in it!"
    15,370
    When i did that, i got a fault code for "system too lean", presumably opening the tank caused an airleak.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    Scanned for codes on VAGcom and these have come up twice now.
    The last one hasn't reappeared but all the others have. Decided to knock the coolant sensor out of the equation and replaced it this morning still to no avail.
    Getting embarrased parking at work and it stalling everytime I go to stick it in a bay. Think it's time to hand the car over to somebody. Anybody recomend me a VAG specialist in Herts. VAG-Tech have moved to Milton Keynes now
    www.passionford.com
    Apr 2004
    12,520
    Looks like throttle body from that. If you don't find one locally I have one from my TQS ere.
    It's failing to adapt and therefore won't stabilise idle properly
    Oct 2009
    190
    I've still got a tb from my old a4 if you want it mate.
  1. revs dying when clutch dipped?
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th September 2012, 20:24
  2. Belt squeak when clutch is dipped or when air con is on???
    By Cash in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th August 2012, 17:11
  3. Revs limited when in first gear, with clutch down.
    By Gavinpipe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th April 2012, 10:57
  4. Engine speed drop when using electrics
    By Rich in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th March 2007, 16:09
  5. Noise when clutch pedal lightly pressed
    By Obion in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th December 2005, 11:39
