AH FabricationsEM Tuning
    Oct 2012
    A4 immobiliser problem
    Been having problems with my immobiliser,
    battery died a few months ago and as it was dying the immobiliser would kick in after 2 seconds of starting which I put down to the weak battery,
    put a new battery on but had the same problem since, meaning to start the car I have to disconnect the battery for 20 seconds and as soon as I switch it off I have to do the same thing again to restart it,
    Its been to the garage twice and put on vag com and 50/504a and on vag com it says the key signal is too weak, the instrument panel is clear of faults, and on the 50/50 software says the ecu is in static mode and won't talk to the immobiliser!!!!
    anyone any ideas?
    i have tried a more powerful battery but that still has the problem so I know it's not a battery fault and my key has no battery in it
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    I think the battery is a red herring.
    The normal immo activation is to shut the engine down after a second or two, so what you describe there isnt anything battery related.
    Have you tried another key?
    Might need a new reader coil, or sometimes the wiring to the coil causes issues.
    TD5 Land Rover Defender build
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,534
    as above iv sorted quite a few B5's with immob problems
    changed the wire from reader and all was good
    easy ish job to do and parts not a lot of £££.
    jcb
    Sep 2005
    uk
    4,077
    where is the reader and how do you remove/replace/repair the wiring?
    "Stick a V8 in it!"
    15,389
    Its part of the ignition barrel.
    Not sure if you can swap the reader on its own, or if you need to buy a whole new barrel though.
    The wiring on earlier cars can prove problematic though!
  1. Help! Immobiliser Problem - Car Won't Start
    By coajt in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2007, 18:06
  2. Immobiliser Problem
    By HNH5 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd June 2006, 19:33
  3. immobiliser problems
    By nugnah1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th February 2006, 21:20
  4. Immobiliser problems
    By paula1806 in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th October 2005, 08:57
  5. I've fixed my immobiliser problem on my '95 A4
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th April 2004, 17:59
