Chris NottBadger5
Results 1 to 11 of 11
    Boost fiend
    Dec 2008
    Swansea
    215
    Cambelt and water pump kit
    I am going to do the cambelt an water pump on my TQS, can anyone recommend the best place to get the kit from for the best price?
    Had a browse on eBay, and can't find an AJL water pump, is the AEB etc one the same?
    Thanks,
    Nick
    99' A3 1.8T Sport KO3s Custom Code stage 2 - Current
    99' A4 1.8T Quattro Sport 180 - Sold
    97' A3 1.8T Sport KO3s 236 BHP - Sold
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    492
    Aeb is identical mechanically so water pump will fit ok.
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    Boost fiend
    Dec 2008
    Swansea
    215
    Cool, thanks mate. Will the AEB cambelt fit too?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,106
    Yeah it will just make sure you get a decent kit with a tensioner damper ie conti-tech or something similar also get the revised water pump with a metal impellor not a plastic one.
    Boost fiend
    Dec 2008
    Swansea
    215
    Cheers for that, where's the best place to buy the kit from and for the best price?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,287
    There are two different kits depending on chassis number. I buy contitech kits from jason at all german.
    TD5 Land Rover Defender build
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,500
    Is there? Ah bugger, I bought an AEB kit to go on mine
    Boost fiend
    Dec 2008
    Swansea
    215
    Whats the difference between kits depending on chassis number then?
    mines a T plater do you know what one I will need?
    "Stick a V8 in it!"
    15,287
    Its the arrangement of the tensioner roller thingy.
    Early cars had a thermal tensioner, which was later changed for the hydraulic version.
    Most early cars have been converted to the later style by now, but the tensioner roller that gets retrofitted is different to the one for cars that came with the later style setup originally. Theres a sort of built in spacer shim thing.
    The belts the same, and if you've got an early AEB kit you can use a combination of the old and new bits to make it work.
    I had it the other way round on my old FWD. I bought a late model kit and had to use the shim piece from the old tensioner roller to make it work.
    Boost fiend
    Dec 2008
    Swansea
    215
    I have been quoted £149.85 inc postage and vat for full conti-tech cambelt inc tentioners etc and water pump, does this sound about right?
    Apr 2004
    12,500
    Sounds about right with hydraulic thing
    Quote Originally Posted by Nick101 View Post
  1. Cambelt and water pump change (parts)
    By Geraldy212 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th December 2011, 20:56
  2. cambelt and water pump advice
    By Ballcrusher in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2008, 01:14
  3. cambelt and water pump
    By dantheman1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2007, 13:01
  4. Cambelt and water pump
    By GarryA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2006, 19:47
  5. v6 30v cambelt and water pump change what tools?
    By dummi in forum General Technical / How To
    Last Post: 30th December 2005, 10:46
