    imported_AudiOwner96
    1 cylinder failed. Ignition module needed... Ł800 !?!?
    My second engine cylinder just failed in my '96 1.8t sport. I tried changing round the spark plugs to see if it was that - no. Not the spark plug connectors either so took it to a garage.
    They looked at it and said it was going to need a new 'ignition amplifier module'. Quote including parts = Ł800.
    They reckon its a very common problem on high milage A4's of this age.
    Any Comments??
    Dec 2004
    17
    Re: 1 cylinder failed. Ignition module needed... Ł800 !?!?
    I had this same problem and had it repaired at an Audi dealers for a lot less than Ł800.
    My A4 has done 136k so you are not alone.
    Dec 2003
    oxfordshire
    9
    Hey bandito,
    I had what sounds like the same problem, one cylinder stopped firing. The module is about 2 inches square and lives on the airbox lid, with a connector either side. Its only held on with 2 screws so is easy to change. I got mine from AMD in Bicester, I think it was about Ł90 or so.
    I hope it is the same module. The Haynes manual calls it the 'power output stage for ignition coils module'.
