EM TuningSky Insurance
Results 1 to 10 of 10
    Apr 2012
    Lymm, Cheshire
    70
    Argh! Urgent help.
    Posted a while back that my brakes seem to be sticking. To the extent that every now and then the front left will smoke it gets that hot.
    Garage checked and said they could find anything wrong.
    This morn the brake pedal hit the floor with no resistance at all. Hardly braking in fact. Yet the front left is still gettin hot as if stuck on?
    WHat would cause the pedal to feel like this?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Faulty ABS pump, the valves can sieze preventing the fluid from returning to the cylinder, thus holing the brake "on"
    Apr 2012
    Lymm, Cheshire
    70
    Argh! Urgent help.
    And making the pedal feel weak as piss?
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,642
    Yep, as there will be very little fluid in the master cylinder...
    Currently rolling in a SKODA!!!
    Apr 2012
    Lymm, Cheshire
    70
    Argh! Urgent help.
    Ok guys thanks. Wish the garage was this helpful. Just hoping ill be able to get it home after work
    Apr 2012
    Lymm, Cheshire
    70
    Argh! Urgent help.
    To clarify. Is the abs pump and abs module the same thing?
    DIY job or a garage?
    jcb
    Sep 2005
    uk
    4,077
    Sounds like the Module
    BBS Reman with recon it for you.
    you could always pull the module and see if that solved the problem
    you will effectively have no ABS but you can still drive.
    Just tape and seal the open housing when you take out the module.
    front passenger wheel off job I am afraid
    remove wheel arch lining and washer bottle and then torx screws on front of module
    Apr 2012
    Lymm, Cheshire
    70
    Argh! Urgent help.
    Urgh. Sounds complicated. Would removing a fuse do the same thing?
    I'd rather have some braking than none at all whilst I figure out what to do...
    Apr 2004
    12,520
    Id bet its the pump not the module that's faulty, so removing the fuse has no impact as the hydraulics can still stick preventing fluid returning and / or cycling fluid within the valve block rather than allowing it to reach the brakes
    Apr 2012
    Lymm, Cheshire
    70
    Argh! Urgent help.
    That does sound more like my problem.
    Seems to affect the front left more from what I can see..and feel. Red hot. Starting to fall out with this car now
  1. HELLO ALL - URGENT HELP REQUIRED - READ MY POST BE
    By leespears1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2004, 19:38
  2. Urgent help needed!!!!!
    By Stuart_A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2004, 17:03
  3. URGENT Help Please
    By [Dave B] in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2003, 17:06
  4. URGENT HELP NEEDED... WHAT WOULD CAUSE....
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2003, 07:50
  5. Urgent help needed
    Last Post: 13th July 2003, 09:02
