EM TuningSky Insurance
Results 1 to 14 of 14
    Oct 2009
    190
    Horrible noise on fast acceleration
    As title difficult to explain the noise but definatly not healthy, only happens on full boost in 1st and 2nd. F**ked engine mount maybe?
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,843
    Quote Originally Posted by steady jay View Post
    ???not if it's coming from the roof & sounds like a squashed chicken, mate.
    a bit more detail on the noise would help.
    2009 A3 SB 2.0T DSG S line
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    Turbo
    tyres
    water pump
    cams
    brakes
    bearings
    alt
    etc etc.
    Oct 2009
    190
    Metal binding metal. N/S/F of the car
    bez101's Avatar
    Jul 2008
    8,480
    wheel bearing
    turbo
    try to explain the sound.
    Alex C's Avatar
    Lizard, Cornwall
    2,600
    high pitched?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    bez101's Avatar
    Jul 2008
    8,480
    dentist drill ?
    im thinking turbo.
    Oct 2009
    190
    I meant passenger side, always get O/S and N/S mixed up. It'll only happen briefly when on peak boost around 3.5k revs but as said only in 1st and 2nd. best I can explain it is it's like a judder noise.
    Oct 2009
    190
    Quote Originally Posted by Alex C View Post
    high pitched?
    No mate quite a deep noise
    bez101's Avatar
    Jul 2008
    8,480
    Metal binding metal ?
    judder noise ?
    best thing is record said noise or take it to a garage.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,843
    clutch slipping?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,135
    It will be your 1/2nd syncro hows the gears from cold are they quite stiff difficulty selecting 2nd from cold if so i have the same problem you can hear it slightly at idle then if you slowly dip the clutch you hear the noise disappear, it could be something else im just going off my symptoms which i the the syncro meshs are goosed on my 1/2nd syncro hub !! I just live with it, for now that is lol
    Oct 2009
    190
    Was thinking its gearbox related as it remapped with 168,000 miles I reckon it's has quite a few full throttle starts and 1st/2nd just can't can't any more abuse. I'll just live with it till it dies. Then strip the car...
    Nov 2012
    Try the carrier bearing on the drive shaft. It made on helluva shudder, and it was centralized in the car. You could feel it right under the arm rest... It didn't do it all the time. I guess it just went haywire when you upset it. Tried to get a bearing from the dealership with no luck. They wanted to sell me the entire drive shaft assembly for $1200. 034 motorsport sells just the bearing. Hope this helps.
  1. Strange noise when reversing/accelerating from a standstill
    By Grant in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1 Week Ago, 07:51
  2. whine noise linked to accelerator position
    By styleinnovations in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th June 2007, 22:40
  3. Horrible Noise! Steering Rack or Pump?
    By Hairy Ballbag in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th April 2007, 23:20
  4. What was that noise!! WOT acceleration 2nd to 3rd Bang!!!
    By IanL-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2005, 10:12
  5. Squealing noise under hard acceleration
    By dcallaghan in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th October 2004, 13:12
