Volks AutosAH Fabrications
    Nov 2011
    25
    Interior fans not working (climate control)
    Hi guys
    I've got a '97 TDi 110 with climate control and the interior fans have suddenly decided to stop working. The climate control panel works fine and I can hear the flaps moving when I change it from windscreen/interior etc. Sometimes the fans will start to work when I'm doing motorway speeds and they work perfectly from then on until I turn the car off again.
    Any ideas what the issue could be? I'm looking to sell the car soon so would like to get this sorted asap if possible.
    Aug 2010
    1,540
    it'll be the motor itself mate. brushes will be worn, too worn to start itself turning. but it'll work on the motorway as when your doing 70 theres enuf air flowing thru the fan to actually turn it without needing power which starts the motor working when you actually switch it on.
    very easy to change the unit.
  1. Interior lights not working
    By 02audis3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2010, 09:13
  2. 1999 A6 AirCon fan not working: cause?
    By SiliconS in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 21st August 2007, 21:24
  3. Fans not working!
    By imported_razputin in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2006, 09:59
  4. New Climate control unit, Fan not working
    By imported_Astwell in forum General Technical / How To
    Last Post: 27th January 2005, 20:39
  5. internal fan not working
    By sahk in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th September 2004, 20:06
