Badger5Volks Autos
Results 1 to 9 of 9
    Jan 2011
    Aberdeenshire
    646
    Alternator coming 'on-line' issue
    I'm now back to electronauting Mrs PaulFs' Avant.
    The problem is the alternator sometimes takes a long while to come on-line.
    On my saloon, I start the car, and the voltmeter drops to 10-12 volts or so. Once started, the battery recovers, and the voltage goes up to 12-13 volts. After a brief wait (less than a minute) the generator comes on-line, and the voltage goes up to 14-ish volts - and a 'click' is heard.
    On hers, after start the battery recovers, but the voltage can take an age to come up, although it is above the 13 volts. It is worse in the cold, being almost unnoticeable in the summer. If this is in the winter, putting lights, heated seats and blower on cause the voltmeter reading to drop, and the voltage actually does - the lights dim!
    When it does eventually come on-line, the 'click' is heard, and there is no further issue
    I have changed dashboards (for another reason) so it's not the gauge, and I've changed the alternator for another (used) unit, so think it unlikely to be that. I also changed the battery for a giant sized unit - still the same! What brings the alternator on-line - I assume there is no dedicated GCU, so assume a relay control somewhere?
    I haven't looked into the wiring yet - as once again, I have SVG Viewer issues!!
    Has anybody else had this fault?
    It's not the end of the world, but with the cold, dark Scottish winter lurking I would like to sort this for her.
    Paul
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Jul 2007
    London
    3,241
    That click you hear is the glow plug relay...
    FOR SALE:
    Jan 2011
    Aberdeenshire
    646
    Thanks Chris,
    I assumed the click was some kind of GCU relay
    Could it be that the glow plug relay is sticking a bit and causing the voltage to be dragged down? (I also have a new Audi CTS fitted)
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,378
    I've noticed something similar on our Avant. Obviously i dont have glow plugs, so after starting the voltage does come straight up to 14v, however apply some electrical load (heated rear screen, blowers, lights) and the guage will drop back from 14. More stuff you turn on the more it drops, and on a cold winter morning with everything on you can get it down as far as 13v.
    The saloon however doesnt do that, it stays happily at 14v with a normal electrical load.
    Whats really odd, is that it does it regardless of the engine RPM.
    Its fair to suggest a large electrical load with the engine idling would cause the voltage to dip, the alternator can only put out 20-30A at idle, but once you raise the revs the alternator catches up as its output climbs to its rated 90A or whatever.
    However on the avant, the voltage drop stays when you rev the engine. This leads me to thing its a wiring issue like a faulty earth strap, or a faulty lead between the alternator and the battery, but i must admit i've not actually tried to see whats causing it yet.
    My first plan is to connect a jump lead between the engine block and the battery negative terminal. This will rule out the earth straps
    TD5 Land Rover Defender build
    Jan 2011
    Aberdeenshire
    646
    I've tried the jump leads when I was looking into my dash fault. I also did a resistance check.
    I assumed it was the alternator dying - so fitted another. It is strange, because as you say the revs don't make a difference.
    It really seems to be that there is a controller not switching it online fully - maybe a dirty contactor/relay?
    Even more strange is that your Avant has the fault, and not your saloon - the same as us!
    "Stick a V8 in it!"
    15,378
    Get a multimeter onto the positive terminal of the alternator with the engine running, and see if the alternators actually putting out 14v.
    If it is, but theres only 13v at the battery, then either the live cable between the alternator and starter, or the starter to battery cable isnt large enough.
    On the 1.8T theres no controller or relay, the alternator is just wired directly to the battery (via the starter wiring).
    Jan 2011
    Aberdeenshire
    646
    I'll try that over the weekend - Mrs PaulF is at work in it today, and I'm back to work tomorrow, so it'll be saturday before I can look at it.
    I'll be fun trying to do that on a 2.5 with it running!
    If there is no control system on your 1.8T, I very much doubt that I have anything.
    Aug 2010
    1,540
    the only "control" is the blue exciter wire on the back of the alternator. this comes from the instrument cluster, in the olden days to the battery light on the dash and goes live when running to extinguish the light. id check the continuity on this wire. cus if its broken (as on my neighbours skoda felicia a few months ago) it simply wont charge but the light wont be on either! but a high resistance might cause poor charging? without the light being on?
    as this wire goes thru the plugs into the car under the box where the engine ecu lives. that'd be my first port of call. looking for corroded pins in there.
    Jan 2011
    Aberdeenshire
    646
    Thanks Murran,
    I could be an exciter issue - although as it does charge, the wire won't be broken. High resistance is a good possibility.
    I'll have to look into the circuit from the dash and get the meter out. A straight resistance check end to end should be fairly straight forward............
  1. Replies: 1
    Last Post: 26th September 2011, 14:57
  2. 1.9 tdi avant did it come in s line, sport or just se?
    By p1tse in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd January 2011, 22:37
  3. Weird noise coming from alternator????
    By a3 quattr0 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2010, 19:21
  4. a few issues with my 2.0 tdi (poor mpg and suspected alternator belt tensioner seizin
    By andy16vturbo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 12th March 2010, 02:18
  5. Used A3 2.0 TDI DSG S-Line - Buying tips & issues?
    By gti25 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th February 2008, 08:03
