Volks AutosJMB Retrofits
    Jul 2012
    noise when i brake, pls help
    Hi everyone, i have just changed my front brake pads on my Audi A4 1.8T turbo saloon year 2000.
    When i brake i have a tinny clunk sound when you first brake, when you contunue to press the peddle there is no further noise.
    Before i changed the new brake pads there was no noise's when i broke using the old pads, the noise sounds if its the front right (offside) any ideas ???
    John
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    are they cheap aftermarket pads? if so it porbably vecause they are not quite perfect fit and so move a fraction on initial braking, wont do any harm apart from being annoying lol,
    i had same problem with mine until i swapped for decent pads
    Jul 2012
    Thanks for the reply, a guy replaced them for me so not sure whats pads they are??? Guess it won't be the secure metal clip which secures the pads???
  1. Strange noise from rear brakes.... When driving..?
    By Rafkoo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th September 2009, 13:03
  2. A3 nocking noise when cruising? HELP
    By paul_a3_tdi130 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2009, 15:48
  3. Groaning Noise when applying medium braking????
    By JGrant1285 in forum Handling
    Last Post: 17th March 2007, 16:18
  4. Noise when braking at high speed ?
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2004, 15:09
  5. Annoying Noise....Pls help.
    By m4tyj in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th November 2003, 09:54
Tags for this Thread
