Results 1 to 9 of 9
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    Bugger!cracked sump!
    while changing my front arb i noticed a small crack in the sump,about 1/4 inch long.Is there anything I can use for a temp repair?Am thinking something like jb weld?
    thanks in advance
    tony
    Jan 2011
    Aberdeenshire
    646
    I've fixed a cracked/holed (aluminium)sump by riveting an aluminium plate onto it, using plenty of two part rubberised sealant between them.
    If it's a small crack, file a small groove along the crack to give your filler material some purchase, and fill it with your JB weld or similar.
    It'll be fine for a long while!
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    cheers for the reply mate,am gonna get some stuff in a bit,and some fresh oil.
    tony
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Chemical metal and apply over the crack and about an inch around the crack to patch it over.
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    all fixed now,JB weld and new oil,so all good!
    thanks for the help
    tony
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    Can this JB weld be used on the outside of the sump or do I still have to take it off
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Cant see why not
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    Quote Originally Posted by B5 BIKER View Post
    I didn't take mine off,just cleaned it up with a wire brush,then p80 paper,then cleaned any dirt off with thinners.
    tony
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    Cheers lads
    maillot give it a go and see
  1. Cracked my Sump
    By docurley in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd July 2008, 11:29
  2. small crack in sump
    By daz2347 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd July 2007, 00:07
  3. Sump Guard
    By Mo-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2003, 11:30
  4. Replies: 5
    Last Post: 31st July 2003, 08:46
  5. A4 Cabriolet windsreen cracks
    By 20006179 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th June 2003, 12:17
