******!cracked sump!
tonya4
TDi Powerrrr
North Devon
while changing my front arb i noticed a small crack in the sump,about 1/4 inch long.Is there anything I can use for a temp repair?Am thinking something like jb weld?
thanks in advance
tony
I've fixed a cracked/holed (aluminium)sump by riveting an aluminium plate onto it, using plenty of two part rubberised sealant between them.
If it's a small crack, file a small groove along the crack to give your filler material some purchase, and fill it with your JB weld or similar.
It'll be fine for a long while!
cheers for the reply mate,am gonna get some stuff in a bit,and some fresh oil.
tony
Chemical metal and apply over the crack and about an inch around the crack to patch it over.
all fixed now,JB weld and new oil,so all good!
thanks for the help
tony
Can this JB weld be used on the outside of the sump or do I still have to take it off
I didn't take mine off,just cleaned it up with a wire brush,then p80 paper,then cleaned any dirt off with thinners.
tony
19
2K
726
860
606
9
jcb
