EM TuningJMB Retrofits
Results 1 to 16 of 16
Thread: big turbo?
    Oct 2012
    Manchester
    24
    big turbo?
    hey guys i was just wanting to know whats the best big turbo upgrade to go for i have a a4 b5 1.8t all standard but want a bigger turbo i was thinking t3/t4 but wasnt sure on what was best to go for if anyone could give me any thoughts will help alot
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    Define "best"!
    You need some goals first. Whats best for you wont neccesarily be best for me or anyone else.
    Personally i suspect a T3/T4 would be hugely laggy on a 1.8T and wouldnt really be very nice to drive.
    A GT28RS is likely a good fit for the 1.8T that wont be too laggy, but will offer something like 320-350hp.
    Another option might be a T3 60trim from a Sierra Cossie 4x4, similar in size to the GT28RS but a bit less efficient, should do 300-320hp.
    Ofcourse if you have lesser power goals then a different set of options would be there, and similarly if you want 500hp then it'll be a different set again.
    TD5 Land Rover Defender build
    Oct 2012
    Manchester
    24
    I would like 300/350 so the gt28rs sounds like the one would it be safe running a gt28rs with a stock engine the last thing i would want is to stick one go down the road and blow the engine
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    497
    Rods would be on the list for me personally, probably intergrated engineering ones.
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    Oct 2012
    Manchester
    24
    Would it be safe to run standard rods
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Id be putting rods in if your over 260hp as i wouldnt want to run the risk of bending one or even letting go and going through the block.
    Oct 2012
    Manchester
    24
    Cool ok thanks for the feed back ill prob just play it safe for now and get a k04 then think ill go big when i have the cash what's the turbo u got in yours bradderz
    Aug 2010
    3,138
    Its a hybrid K04 from frankenturbo but it has slight shaft play so its not getting tuned yet its on stock map got a big list of jobs to do first getting it mechanically sound then im going to be looking into doing a engine rebuild with rods/pistons or may even look at a 2.0 stroker kit but thats going to be a work in progress. I wouldnt even get a K04 before a BT i would do it right first time i sort of regret going hybrid and should of gone straight to a GT28 but we learn from our mistakes i guess but i will get there one day with the car lol
    Oct 2012
    Manchester
    24
    That's cool which would u says best a k04 or a hybrid k04
    Aug 2010
    3,138
    Hybrid will be best option with supporting mods ie 3inch maf 3 bar fpr injectors fmic you should see 260-280hp depending on turbo size, frankenturbo have recently released the F21 longitudinal which has a slightly bigger compressor wheel than the F4 i have fitted, it really is a good bolt on package for just under 1k
    Oct 2012
    Manchester
    24
    Thats pretty sweet that then ill go and have a look at frankenturbo see what they got would audi s3 or tt injectors be sutable
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    The search for power is a long and expensive route to travel. Be aware other componants will wear out quicker too.
    Apr 2004
    12,523
    Depends what engine you have installed, if you have a DBW APU engine then S3 / TT injectors are fine, if it's an AEB you will need to use some bosch redtops or similar
    Quote Originally Posted by b5boy View Post
    Oct 2012
    Manchester
    24
    Ill prob have to go with the Bosch ones mines a AEB what size cc injectors would suit that
    Apr 2004
    12,523
    depends on turbo/MAF and tuner choice tbh
    Oct 2012
    Manchester
    24
    Ill just the guys were Im getting the turbo from see what they recommend
  1. Few questions about BIG turbo conversions
    By Grant in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2005, 18:07
  2. here are power maps of chipped and big turbo cars
    By dunk in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2005, 18:37
  3. MTM big turbo
    By DuncS3 in forum Tuning
    Last Post: 4th January 2005, 17:10
  4. Replies: 25
    Last Post: 20th August 2004, 10:19
  5. Big Turbo Alternative
    By StephenBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2004, 12:40
