EM TuningMonster Motorsport
    132
    Exhuast Leak only from Cold 1.8T
    I have an annoying small exhaust leak from cold which goes after a couple of mins driving. It happens even when the car is warm and you start it up and drive away. The manifold to turbo gasket, turbo to cat and cat to downpipe gaskets are all new and the downpipe is new. I've checked the turbo to manifold bolts are tight.
    What can it be ? Is there a fair chance the manifold gasket has gone or the manifold nuts are loose ? Can't think of anything else.
    This all came about after removing the turno to put a new actuator on.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    hmm, i had something similar and it was caused by a snapped stud on the cylinder head.
    Mine made an awful farting noise under load as well though once over about 5psi of boost.
    Did you use genuine gaskets and bolts when you changed the turbo?
    TD5 Land Rover Defender build
    132
    Yeah, all genuine. It goes after after a few mins driving. I'm just wandering if the manifold gasket has deteriorated.
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    405
    Had a similar problem on an old car which ended up being a cracked exhaust manifold. Guess tubby gasket/mani to head gasket could do similar.
    132
    Cracked exhuast manifold sounds feasible. How common are they for cracking ?
  1. starting from cold
    By mordz in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2007, 18:47
  2. Clutch judder from cold in damp weather
    By Macduff in forum Diesel forum
    Last Post: 1st March 2007, 09:47
  3. rattle from cold
    By findbar in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st January 2007, 00:46
  4. rattle when starting from cold
    Last Post: 30th October 2006, 13:51
  5. High pitched noise when starting from cold
    By ajek in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th November 2004, 15:00
