Chris NottJMB Retrofits
Results 1 to 7 of 7
Thread: Door Mouldings
    Aug 2009
    Dorset, UK
    176
    Door Mouldings
    On my Audi the rubber door mouldings that run down the outside of the door at the bottom (clip on) have got to be replaced, There is a metal insert that has corroded. Does any one know where I can get replacements I need for both the front doors. It is a W reg year 2000 car Saloon if that makes any difference.
    TDi Powerrrr
    Aug 2010
    North Devon
    404
    I got mine on ebay,just over £120 for all four doors.The new ones have a plastic strip instead of the metal so will never corrode.
    tony
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,113
    Why not Upgrade to S4 painted ones ??? I got mine for just shy off 120 just in process of preping them ready for paint i need a good rain free weekend then ill be slapping some paint on. Works out cheaper if you DIY.
    Oct 2011
    West Yorkshire
    67
    If you check my threads there's one for these. A company on eBay will do them at a discount. I got mine all in posted for £109. Make sure you get the new version with the plastic insert instead of the metal one so they won't rust in the future.
    Aug 2009
    Dorset, UK
    176
    What are the difference between S4 and normal door mouldings?
    Jan 2012
    Malton
    276
    Is it not possible just to clean them down and secure with some no more nails?
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP
    Aug 2010
    3,113
    Differance with S4 ones is there painted and. Clip on to a full plastic backing trim and look a lot better along side some s4 skirts. Theres some on ebay us and de but are a bit pricey to what they go for here, best thing to do is search for any S4's being stripped for parts and just message them for a price also adidasandy is breaking his avant so there the first place to look.
    heres a comparison
    A4
    S4
  1. Audi A4 lower door mouldings for sale
    By jey in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th August 2009, 16:50
  2. Wings + door mouldings wanted
    By 951 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th February 2009, 20:50
  3. Sline Door Mouldings For Sale
    Last Post: 7th October 2008, 23:19
  4. removing door mouldings..
    By J7USS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th June 2008, 19:30
  5. Door Mouldings
    By Stepho in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th September 2005, 09:19
