Results 1 to 8 of 8
    Steve B5 Biker's Avatar
    Jan 2012
    SOUTH YORKSHIRE
    128
    Intermittant ABS/ESP light and other issues related
    Hi firstly a brief car history.
    A4 B5 Avant 2.5 tdi
    18" BBS REPS
    remapped, fmic
    coilovers,custom exhaust.
    Carbon roof etc....
    Have been getting ABS light coming on intermitantly over a few weeks now ,
    some times as soon as you fire up the engine, yet other times i can drive 10 miles before it rears its ugly head,sometimes it stays on untill ive comleted my journey,yet other times it just resets mid journey CONFUSED
    ive had a friends vagcom on and its put up the following codes.
    ABS=01203 Instrument panel electrical connections ?
    ABS=18256 check dtc memory of ecu ?
    also
    Engine code 18259 Data bus powertrain,missing message from brake control menu ?
    Any help or guidance from the Audi Gods.... would be a great help
    Cheers in advance Steveb5biker
    Jan 2012
    SOUTH YORKSHIRE
    128
    I realise this is a very common topic on here
    just need a bit of guidance im guessing abs speed sensors maybe ?
    Sep 2011
    Sunny Bangor. N.Wales.
    288
    i have the same car,,, heard about the ABS rings "snapping" might be worth taking the wheels off and having a look, whilst rotating the cv joints.
    2000, A4 2.5Tdi Quattro.
    Tinted, 3600WATTSLoud
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,318
    If it was speed sensors it'd tell you its speed sensors.
    Looking at your fault codes, theres some comms issues between the ABS, ECU and Cluster...
    Could be a failing ABS module, or corrosion in the wiring somewhere?
    TD5 Land Rover Defender build
    Jan 2012
    SOUTH YORKSHIRE
    128
    Hi Mackers ,thanks for that, the cars booked in monday,having new clutch,with solid flywheel conversion, service oil n all filters changed,pre M.O.T so will get abs checked out with my spanner man, gonna be an expensive couple of days lol..
    Jan 2012
    SOUTH YORKSHIRE
    128
    Cheers for that Aragorn will get it checked out next week will keep u all posted....
    Sep 2011
    288
    you got pics of ya FMIC, i'm toying with the idea
    Jan 2012
    SOUTH YORKSHIRE
    128
    No pictures of instalation Mackers, sorry was already done when i bought the car, can try get some close up shots of it now but RS4 bumper may hide a lot of details....
  1. ABS & ESP Lights Staying On
    By Jiny_P in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2013, 20:28
  2. ESP light and ABS on after brake switch is replaced
    By polar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th January 2011, 14:54
  3. A4 S4 B5 - ABS & ESP lights are on since driving and braking over ice??
    By S4DemonGreek in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th February 2010, 19:55
  4. squeeking brakes and ABS/ESP light
    By glen_jai in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2009, 19:12
  5. ABS ESP Lights on
    By downie in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2007, 20:13
