    Apr 2006
    A, A
    269
    S4 B5 clutch master and slave cylinder bleeding
    Right,
    Replaced both cylinders and just wanted to know how to bleed weather it's pedal down or pedal up?
    Andy
    Aug 2010
    1,540
    pedal up and nipple loose, let it trickle thru under gravity, once fluid is seen at the nipple on the slave. then tighten the bleed nipple, leave the clutch pedal up for 10/15 minutes. pump the pedal up and down a few times. how does it feel? if not right. get your mate to hold the pedal down while you undo the nipple to get a squirt of fluid/air. your mate will now need to "pick up" the pedal off the floor. keep it at the top of its travel for 10 seconds and then work it up and down a few times. hold the pedal down again and undo the nipple again then keep at the top of its travel for ten seconds. repeat until its bled. keep topping up the fluid!
    Apr 2006
    A, A
    269
    Spot on ta
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    I just used eezibleed on mine. Keep the pressure low though, 5psi is enough.
    TD5 Land Rover Defender build
    Apr 2006
    A, A
    269
    Car is now being brokefor spares, gearbox still at fault so gave up :-(
  1. Clutch slave cylinder or master cylinder ?
    By ColinS in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2013, 21:29
  2. Bleed Clutch slave cylinder
    By Cam in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th December 2010, 12:57
  3. Clutch Slave cylinder gone again
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th June 2010, 15:10
  4. Clutch Slave Cylinder
    By aragorn in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2010, 13:29
  5. Replacing clutch slave cylinder
    By Tifun in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th November 2009, 10:58
