Volks AutosSky Insurance
    Sep 2012
    96 A4 Power steering Question
    1996 A4 Quattro
    84k miles on the motor
    Just bought my first Audi the other day for a steal (or at least I hope) it has a few issues and I know a bit about cars so I figured I could fix all the small problems.
    It whines a lot when @ low speeds but the level is okay, so I lifted the front wheels off the ground and turned the wheel with the car on and the entire time I could see bubbles coming up inside of the reservoir.
    My question is: Does this mean their is a leak in my powersteering lines somewhere? or is this normal?
    Aug 2010
    1,540
    is it a v6? theyre normally a bit noisy and can last years like it.
    the fluid churning inside the reservoir and tiny bubbles are normal. if there were any leaks fluid would be leaking out, not air getting in.
    as for the noise, how dirty is the fluid? probably wants changing tbh. if that doesnt quieten it down then it'll want a new pump.
  1. Power Steering and headlight question??
    By S3featesV9 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2011, 14:05
  2. quick power steering question
    By polsonm87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th May 2010, 00:06
  3. Power Steering Fluid
    By TrueNilbog in forum TT/TT-S/TT-RS Forum
    Last Post: 3rd October 2004, 02:24
  4. Noisy power steering?
    By GeorgieMcC in forum A8/S8 forum
    Last Post: 18th February 2004, 12:29
  5. Power Steering Fluid
    By blued in forum General Technical / How To
    Last Post: 28th August 2003, 13:23
