Volks AutosAH Fabrications
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,698
    Facelift Bonnet removal
    How easy is it to remove the bonnet on a facelift A4?
    The bonnet arm bolts like easy enough along with the supporting leg. Its the washer pipes I am curious about.
    I am needing to get the bonnet painted and am thinking it may just be easier to get it painted fixed to the car.
    A4 1.8T Quattro, FMIC, Coilovers, B&M short shift, 312mm Brakes, Stage 4 clutch, Awe Gauge, Uprated antiroll bars, plus more bits. Pics Here
    TDi Powerrrr
    Aug 2010
    North Devon
    401
    The wiring is easy,so are the washer pipes,though I broke the lug off one of the washer jets when removing the pipe.It may be better to cut the pipe off.The bonnet strut is just a clip.
    hth
    tony
    CraigG's Avatar
    May 2008
    188
    i imagine they could get a better colour match painting it on the car?
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,698
    They have the other front panels already so was thinking they could match the bonnet against them?
    brasiliangringo's Avatar
    Mar 2010
    496
    I am no painter, but i do know that a proper job involves blending the panels which requires everything to be in place.. That is if you want a proper finish that does not show from panel to panel.
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,698
    Hopefully works out ok, I thought removing the panel would give a better coverage and make it look more like it had not ever been sprayed. Fingers crossed.
  1. Facelift Bonnet Removal
    By tonya4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th July 2012, 14:10
  2. facelift bonnet on pre-facelift B5?
    By riverstyx in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th January 2011, 23:02
  3. 8P FACELIFT BONNET
    By S3_Jacko in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th September 2010, 20:58
  4. WANTED: Silver facelift bonnet and boot
    By Geeman in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th May 2009, 10:44
  5. pre facelift bonnet needed
    By Lex in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th March 2009, 00:17
