Badger5Monster Motorsport
Thread: Vacuum hoses?
    Sep 2012
    East Sussex
    11
    Vacuum hoses?
    Just been looking at the vacuum hoses on my 2.8 30 valve and they seem a bit brittle with the fabric flaking off them. I notice as well that one of them operates a valve on the front of the inlet manifold. What does this do? Reason i ask is mine has a stutter at low revs up to about 2500rpm ( see my other post) and was wondering if this valve is not opening properly causing the stutter. Thanks.
    Mar 2012
    Hi James 33.
    I would change out the vaccum hose for silicon. (try APmotorstore.co.uk who stock ASH silicon stuff) Dia 4mm a couple of quid a meter. Made a big differance to my engine ACK. Clean the throttle body if not done recently, and when you took the plugs out, (I read your other post.) Was there oil in the plug pocket? If so change the rocker seals, my be shorting out the spark and that is why the back two plugs are black. More so if you park on a hill. The crankcase breather pipe will also be very brittle by now, and may need changing. Very very expensive from the dealers.
    If you have the Auto triptronic, I would change the AT oil and filter. Audi service book I have recommends every 60K. Which the dealer seemed to ignore. Nice engines and run and run if looked after.
    Sep 2012
    East Sussex
    11
    Hi i checked for leaks on the valve cover but they seem ok and the plugs where dry. Will change the vac hoses soon i think even though its running really nice now.
  1. air/vacuum hoses
    By dribz-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2009, 16:55
  2. Vacuum Hose undernearth throttle body
    By S3mad in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th August 2008, 19:39
  3. Charcoal Filter - Broken vacuum hose
    By nershen in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2007, 20:13
  4. Split vacuum hose - part number required
    By prel2000 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st May 2007, 08:50
  5. Where to buy Vacuum hose
    By awmw in forum Diesel forum
    Last Post: 23rd February 2007, 13:46
