Volks AutosMonster Motorsport
Results 1 to 14 of 14
Thread: New Member Here
    Turbo!
    Sep 2012
    Co. Durham
    9
    New Member Here
    Just like to say Hi as i have just signed up and am new to this
    So i bought myself and Audi S4 B5 on friday night. I bought the car knowing there was a problem with it. It did say the car needed a clutch so i didnt bother testing it i just put it straight onto the back of the truck and took it home.
    Had a check over it yesterday to find i can not get into 1st or second gear weather or not the car is running. It went straight into 3rd no problem at all and drive fine into 4th, 5th, 6th and reverse with no sign of slipping from the clutch.
    Just wondering if anyone has any idea what it could be? i am hoping its just a cable or something and not the gear box :/
    I do have a few plans for this but will update once i decide on what i am going to do
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,336
    ​Hi Eddy, welcome to audi-sport.net. Nice looking car. Hope you get your car sorted out soon. Im sure one of the guys will be along shortly to advise you. Enjoy the forum. x
    Some useful info to read. x
    A4/S4 B5 FAQ List
    Look here before posting, loads of Technical information for A4s and S4s
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    Turbo!
    Sep 2012
    Co. Durham
    9
    Been told it may need new gearing and synchro rings
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,336
    Quote Originally Posted by eddy_turbo View Post
    Well that sounds a bit expensive, hopefully its something else. x
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,873
    1/2 syncro are a common problem on the 01E box !! New genuine ones are stronger so get one from stealers or you will only be doing it again !!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Quote Originally Posted by Bradderz_1988 View Post
    Whats involved in changing the synchros? Just wondering if its worthwhile me doing whilst ive got the engine and box out
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    To the OP It's common with the S4 01E boxes, I think i saw this one on Egay, was 1600 iirc. So at that price a used box for a few hundred quid still makes it a bargain tbh.
    Lee, not sure, I am pretty sure it's something best left to specialists
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Quote Originally Posted by Byzan Pics View Post
    Hmmm, mine is OK. Its just quick shift between 1st and 2nd that can be a bit hit and miss
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    Its a progressive issue.
    The synchros on 2nd get weak causing missed shifts. The grinding that results from the missed shift damages the shift collar.
    If you never grind the gears, and just live with having to take 2nd gear easy, then it'll go on for a while like that.
    It only takes one particularly hard grind and you end up with a box like the OP's
    The fix involves new synchros and a new shift collar, its about £500 in parts, plus labour for a transmission specialist to strip the box and fix it.
    TD5 Land Rover Defender build
    Turbo!
    Sep 2012
    Co. Durham
    9
    Yes it was the one on ebay. Got it cheap so not fussed about paying to fix it really. There is another gearbox on ebay at the minute i might try get hold off but failing that i will repair this one.
    Is it an engine out job or can it be dropped out with the engine still in
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Its awkward but it will come out without the engine
    Turbo!
    Sep 2012
    Co. Durham
    9
    Quote Originally Posted by LeeT View Post
    Ah nice one. Anyone have any idea what 1st and 2nd gear synchros will cost me from audi
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    As Kev(Aragorn ) posted below i would assume. £500
    Turbo!
    Sep 2012
    Co. Durham
    9
    Cool
    I have managed to source a gearbox for now and will rebuild mine over time. Noticed you can get a longer 6th gear for these as well what will give you a higher top end what would be ideal for the ring trip next year B)
    The car needs a few bits and bobs to get it mint again but will have to post up photos once i get the car back from the garage so people can tell me whats what.
    Thanks for all your help so far
  1. New Member Here!
    By Andy@APR in forum The Welcome Section
    Last Post: 28th November 2007, 06:31
  2. Hello, new member here
    By emma_88 in forum The Welcome Section
    Last Post: 7th October 2007, 16:03
  3. Hello all, new member here.
    By JayB5UK in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th January 2006, 17:59
  4. Hello - new member here
    By Mart in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd November 2005, 11:36
  5. New member here
    By quattrojeff in forum The Welcome Section
    Last Post: 6th November 2003, 19:24
