AH FabricationsEM Tuning
Results 1 to 9 of 9
    Jan 2012
    Malton
    272
    Engine mounts - standard or something racy?
    I think my new B5 is showing all the symptoms of worn engne mounts. Does the forum think I should go to the stealers and get a set of replacement mounts or should I get the ones for the RS4.... oooooooor should I go for some fancy aftermarket ones - bearing in mind I only want her to perform like new.
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    General perception is that the RS4 mounts are a particular upgrade over standard model Audis but not as OTT as proper uprated types if your just using the car on the road everyday, for what its worth, i intend to track the car on the odd occasion but will want it to drive good on the road and as such use the RS4 units on mine.
    Project RS28 build
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    How about 034 motorsport street density? Im torn between these and new RS ones
    Jan 2012
    Malton
    272
    Thanks, Foxy - good advice.
    CraigG's Avatar
    May 2008
    188
    Quote Originally Posted by LeeT View Post
    for the price of OEM, i went for 034 Street Density, purchased direct from 034, they arrived in 3 days, and still worked out cheaper than OEM after you include shipping and duty....
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,698
    I will be fitting Street Density engine and box mounts next week. Think they are what most people in the States go for as compared to oem they are decent value.
    A4 1.8T Quattro, FMIC, Coilovers, B&M short shift, 312mm Brakes, Stage 4 clutch, Awe Gauge, Uprated antiroll bars, plus more bits. Pics Here
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Quote Originally Posted by CraigG View Post
    How do you find them when fitted Craig? I have heard you feel more vibrations etc for the track spec type, are the street units similar in spec to oem RS4 then?
    Project RS28 build
    Oct 2008
    Glasgow
    430
    Mick i use the track density mounts on mine and think they work perfectly. A little more vibration if i am nit picking but nothing to be to fussed about. The street density mounts are still stiffer than OEM rs4 mounts due to them being void free and using a slightly higher durometer rubber. The street density mounts work out at 25% stiffer. For me either density is well worth having.
    CraigG's Avatar
    May 2008
    188
    Quote Originally Posted by Foxmeister View Post
    No experiance about the track density, but my Street Density are great, no noticable vibration for me at all, definetly the right choice for a comfort weighted uprated part!
  1. S4 engine mounting
    By imported_timwiti in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th September 2005, 17:01
  2. Audi 80 Engine mounts knackered?
    By imported_Griffy in forum Classic Audi Forum
    Last Post: 25th July 2004, 13:26
  3. Engine mounts
    By dafunkymonkey in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2004, 12:36
  4. Engine Mounts
    By dbm in forum Tuning
    Last Post: 15th September 2003, 18:00
  5. Knackered engine mount?!
    By davidrees in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2003, 20:50
