Chris NottAH Fabrications
Results 1 to 8 of 8
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    380
    Larger oil filter 1.8T. Halfords Part number?
    Had a quick look but can't find my answer
    Does anyone know off the top of their head what the part number is for the larger oil filter for the 1.8t from Halfords?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Dont buy it from halfords, they rip you off.
    I usually go for the middle size one, ask for a filter for a B6 A4 1.8T with BEX engine code at your local factors.
    TD5 Land Rover Defender build
    snapon's Avatar
    Jul 2012
    36
    06A115615F is the dealer number at around £6 why would you want to buy a piece of crap from Halfords?
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    380
    Cheers guys. Wanted to use halfords as it's within walking distance basically
    This is what I ended up with
    East Berkshire
    177
    Is this the same filter that is used on VW Transporter 5 cylinder engines , or is that an even bigger filter?
    Actually before pressing 'send' I've looked back at my notes from some months ago -- I believe that 074 115 561 is even larger in length.
    I'll probably try one in about a months time when the next oil change is done.
    ChrisG
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,870
    I use k&n oil filter part number is hp-3001 its massive lol !!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Aug 2010
    1,540
    don't use halfrauds. unless you like being ripped off? fair enough if its local enough to walk to. taking into account the cost of fuel in driving to somewhere else......
    griswold's Avatar
    336
    just bought some 5w40 fully syn and free bosch oil filter for transporter for £15.39 del from eurocarparts
    filter pt no. 501440080
    A4 1.8T Quattro sport
    A6 2.4 Avant SE
  1. S3 1.8T AMK - Larger Oil Filter
    By Yohan87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2012, 17:55
  2. Halfords part number check please asap
    By audiv6quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th January 2012, 05:54
  3. Oil Filter Part Number?
    By Point_Audi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st June 2011, 20:24
  4. oil filter part number
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th December 2005, 22:18
  5. S3 AMK Engine - Anyone know the oil filter part number ?
    Last Post: 30th September 2005, 17:20
