Badger5Monster Motorsport
Like Tree1Likes
  • 1 Post By murran
Thread: need some info for few jobs i want to tackle
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    seeing as my car has sailed through its mot, im going to get on and tackle a few jobs i wanted to do on my car but have been putting off or not had time to do , so looking for a bit of info to do them
    1: there appears to be a rattle/vibration noise that comes from behind the passenger side of the dashboard, it sounds almost metalic, has anyone got a pic of whats behind the dash so i could poss work out the source of the noise.
    2:my rocker cover gaskets are leaking and they have slowly been getting worse to the point now that when the engine very hot it smells bit oily, how hard is it to replace the rocker gaskets on a 2.8v6 and any tips, i have looked and it doesnt appear to bad a job just bit fiddly.
    cheers alan
    Aug 2010
    1,540
    2.8 30v? do the leaks seem to be coming from the n/s/f and the o/s/r of the engine? these are where the head chain tensioners are. like the 1.8t ones, under them is a little gasket and a D shaped rubber doofer seal, these leak so if your doing the cam cover gaskets, do these too.
    you'll need the tensioner pad backing off and holding tool to slaken off the chain tension, like the 1.8t.
    the one on the o/s/r is relatively painless but the n/s/f one is an arse as the cambelt back cover (metal bit bolted to the head behind the cambelt pulley) makes it very awkward.
    205man likes this.
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    both banks are leaking but the near side is the worse it seem, they are leaking more from the rear and around the spark plugs, there a small amount of oil there that smells when it gets hot.
    Aug 2010
    1,540
    ive been working on "winchmore's" 2.4 30v recently, ive changed the cam cover gaskets. thats cured the oil leaks into the plug holes and some of the external leaks, but the D rubber bits under the chain tensioners are leaking on his.
    Oct 2011
    West Yorkshire
    67
    The 1.8t gasket is a pain to get it to seal right and I would imagine yours will be the same design. I had an Octavian VRS and it took me a few goes. Make sure the mating surfaces are dry and free from oil. I would recommend using a gasket sealer but make sure it's a high temperature one or it won't work.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,997
    Passenger side behind the dash is the heater matrix, air bag and all the metal work for the air bag.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
  1. Need some info regarding registration please
    By abdus in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd August 2008, 18:13
  2. Need some recommendations for a breaker's yard.
    By boggysv in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th June 2008, 08:33
  3. Help need some info
    By Techimike in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 8th February 2008, 19:44
  4. Replies: 0
    Last Post: 1st February 2007, 15:41
  5. Needs some info please
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2006, 09:22
