Badger5JMB Retrofits
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,091
    Front wheel camber??
    Took my car in to get the alignment done to find teh camber was out on the n/s front wheel. Found the forward most lower arms bush was split, sods law as it was the only bush that hadn't been polybushed. This was replaced yesterday and I went over everything with a fine tooth comb but there still apears to be more camber on that wheel??
    Any ideas, as I'm stumped. Never had the issue before and the car has never been crashed or pranged?
    Life begins at 140mph
    www.passionford.com
    Jan 2011
    Aberdeenshire
    646
    As long as it's within limits, don't worry.
    Manufacturing tolerances can cause differences from one side to another, different loading, damper health etc.
    (I am, of course assuming that you have put the bolts in the correct hole when you did the arms)
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,387
    Mines the same.
    Basically you cant adjust the camber individually, but you can move the subframe over a bit to level it out.
    On mine one side is 1*50' and the other is 1*20', so in that case you could move the subframe over a bit and end up with both sides at 1*35'. However, having a bit of extra camber on the NSF isnt a bad thing, especially with all the roundabouts we have So i've just left mine alone.
    How far out are your figures?
    TD5 Land Rover Defender build
  1. Cat back exhaust for a 99' A4 1.8t front wheel
    By Mushdog in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th November 2004, 01:08
  2. clicking noise as front wheel turns on A4...
    By imported_bpascua in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th August 2004, 21:59
  3. Can you convert from front wheel to 4wd??
    By kano in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th March 2004, 06:27
  4. Replies: 0
    Last Post: 29th March 2004, 23:11
  5. Lack of traction at front wheels
    By cyberdude in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th February 2004, 23:40
