JMB RetrofitsBadger5
    Mar 2010
    125
    ABS Reluctor Ring (rear)
    Just wanting to know if this is in the Hub assembly or the CV on the rear of the Car , i want to see if its got a crack in it or corroded as i am having activation coming from the rear.
    thanks in advance
    Jan 2011
    Aberdeenshire
    646
    On the Quattro, it's on the CV joint.
    The ring is a shrink fit, so you need to get it cherry red before you plop it on (get it the correct way around!!)
    If you go here How to replace front and rear suspension parts (with pics) there is a pic further down of a broken one on the joint, plus how I repaired mine!
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Mar 2010
    125
    thankyou for the Reply mate
  1. ABS reluctor ring
    By rick28 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2011, 15:55
  2. ABS light after rear wheel bearing
    By teo420 in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd July 2011, 23:12
  3. abs rear sensor air gab?
    By jimya4t in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th April 2007, 16:57
  4. abs rear sensor
    Last Post: 7th March 2007, 23:04
  5. rear trunk ring badge? is it just glued?
    By imported_nmb in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th January 2005, 23:30
