EM TuningChris Nott
    Boost fiend
    Dec 2008
    Swansea
    207
    Thermostat and CTS?
    Hi guys, got the common temp and oil gauge don't move much untill idle where they go upto normal 90 degrees, but then drop when move off.
    Is this just the thermostat? Or is the temp sensor faulty too? And will one or both of these cause the oil temp I not work correctly either?
    Cheers!
    99' A3 1.8T Sport KO3s Custom Code stage 2 - Current
    99' A4 1.8T Quattro Sport 180 - Sold
    97' A3 1.8T Sport KO3s 236 BHP - Sold
    Jan 2011
    Aberdeenshire
    635
    It'll most likely be the thermostat.
    The oil is cooled by the engine coolant, so if the thermostat is stuck open the coolant flows through the radiator all the time and thus takes an age to heat. If the coolant is not hot, it will cool the oil too much. Once up to temp, the oil temp should roughly match coolant temp.
    (at least you don't have 2.5 TDis like mine to change 'stats on!!)
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
  1. Thermostat and housing
    By Matt82 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th November 2009, 15:21
  2. Thermostat and Lambda Sensors A4 2.0 (B6)
    By tohowe in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th November 2008, 10:44
  3. Neuspeed Thermostat and Fan switch
    By audi18tdan in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2008, 23:11
  4. MAF and CTS
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2008, 11:33
  5. Thermostats and Water temperature
    By Wak in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st February 2007, 17:07
