EM TuningSky Insurance
Results 1 to 22 of 22
    Boost fiend
    Dec 2008
    Swansea
    215
    My new daily, A4 TQS
    Following on from my other thread asking about the A4 TQS I ended up buying one on friday!
    Travelled from Swansea to Kent to pick it up, what a long day, especially hitting the M25 at rush hour.
    Its a pretty good example, 75k, one owner, full Audi history. Got the Recaro's, Xenon's, Bose.
    The inside is mint, the bodywork has a few scuffs and dings and the wheels have corroded as they all do.
    Mechanically it runs really sweet, bar the ABS light being on which I am hoping is simple fix, ABS ring as I have been told or sensor. Apparently the ABS module has been done.
    I am very happy with it, so smooth and quiet. Dont actally want to lower it in a way as I dont want to ruin the ride, even though all my cars I have ever owned have been.
    Plans for it:
    As this is a cheap-ish daily (thats the plan) as I am buying my first house I dont want to/plan to go crazy on mods.
    Sort ABS problem
    New oil dipstick (broken neck)
    Needs a real good bath as its covered in tar/industial fall out
    Sort out scuffs and dings, one on rear quarter/front wing/bonnet, get front and rear bumpers painted and bump strips on doors
    Refurb wheels
    It needs a remap as it is very flat as my last few cars have been modified 1.8T's and a Focus ST (dont flame me) lol
    Can anyone reccomend a company or a good person for remap? Is it a plug in job so does the ECU need removing?
    I would like a little spoiler for the rear boot lid as it looks very plain, anyone reccomend one?
    Anyway, enough waffling, heres some pics:
    Thanks for reading/looking!
    99' A3 1.8T Sport KO3s Custom Code stage 2 - Current
    99' A4 1.8T Quattro Sport 180 - Sold
    97' A3 1.8T Sport KO3s 236 BHP - Sold
    Aug 2010
    39
    well jealous. But then again i didn't know what i had bought until about 12 months after buying it as was only a stop gap after selling my Focus ST. Hopefully get it looking like your fine example here.
    Boost fiend
    Dec 2008
    Swansea
    215
    Cheers mate, silver hides a multitude of sins, lol
    I ended up buying an Ibiza cupra after my ST as i got bored not having a car after a week, did'nt like it so swapped it for this. Fancied something a little special.
    The ST is a good car, miss the torque of the thing, and the 5 pot growl. Would love an RS3 and have the best of both worlds...
    I would also like to thank everyone who gave me advice and info on these cars in my other thread, Bradderz, Aragorn, Kingfisher, etc
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Very nice indeed recaros are definatly a must, get a boost gauge plumed in first if your saying its 'flat' as it may be something mechanical like the DV or even put a forge item in its place then you wont have to worry about the diaphram collapsing in your oem bosch one all i will say now is that list of yours wont stay that short as mine never does do one thing and another 3 get added to the list lol
    Boost fiend
    Dec 2008
    Swansea
    215
    Thats what I am worried about, opening pandoras box when I start modding, worth it though, just not financially
    I have read the standard TT 225 DV will work as an upgrade? Alternitavely does the Forge 007p work?
    Also what should it be boosting to standard?
    Aug 2010
    3,136
    You should see around 10-12 psi sometimes mine peaks 14 psi, im running a 007p with a green spring but looking to get a yellow spring to see if it performs any better. Sounds good with a open cone filter not to loud like a scooby or the likes.
    Aug 2010
    39
    Is there an easy way to double check the DV? fitted a boost gauge the other day but only wired it in temporally and was reading -0.7 at idle and was reading 0.2 then in 5th it read 0.6 which I believe is what it should be reading.
    Boost fiend
    Dec 2008
    Swansea
    215
    Should the green spring be adequate for standard/stage 1 map power?
    Is the standard TIP and airbox restrictive?
    Got alot to learn about these cars, feel like a right noob as I am fairly clued up about the 1.8Ts in the A/S3 TT Golf etc
    Aug 2010
    3,136
    Green should be ok but personally id switch to the yellow if you up the boost, airbox isnt restrictive youd be best of with uprated intake pipe panel filter and modding the airbox to have a second cold air intake pipe from the o/s bumper grill area to airbox.
    Kenlaw one easy way is to remove it then blow through the bottom port if air passes its fubar if your cheeks feel as if there going to explode your all good lol
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    Quote Originally Posted by Nick101 View Post
    Thats correct the "710" would be fine and a lot cheaper!
    If funds are limited I would concentrate on making sure there are no problems with what you've got. Invest in a Vag Com lead and check there are no underlying problems (e.g.like n75 valve not working etc making it flat) and what's causing your ABS light issue.
    These are great cars in standard form, no need to start modding!
    Boost fiend
    Dec 2008
    Swansea
    215
    I am going up my brothers work tomorrow to get it up on the ramp and have a good look under it.
    Gonna whip the wheels off and have a look at the abs sensors/rings and see what's what.
    I plugged it in at the garage when I bought it, but will have a look and see if there is anything coming up.
    Think it just feels flat as the last few cars I have owned have been not standard.
    See you're from Swansea mate, you got an S4? Any experience with the TQS?
    Boost fiend
    Dec 2008
    Swansea
    215
    How hard is it/what's involved in getting to and changing the abs ring on the rear, think its gonna be the driver side?
    Is the ring part of the cv joint, and has to be changed as one, or is it just the ring that can be done?
    Aug 2010
    3,136
    You could probably remove the shaft and clamp the reluctor back in a vice and clean it up and spot weld the reluctor as a cheap fix !!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    You can get replacement rings from ebay. You need to take the shaft off to get them out though.
    TD5 Land Rover Defender build
    Boost fiend
    Dec 2008
    Swansea
    215
    Cheers guys!
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    Looks nice, love the seats.
    Some people fit the M3 lip spoilers to the bootlid if they want a little spoiler.
    A4 1.8T Quattro
    East Berkshire
    178
    They spent some money when they ordered that, Recaro Bose and Xenons - and it's an early car ( ours is T - mid July 1999)!
    Don't know who does chips for these, this used to be easy (ish) at the time but things have moved on. the ECU has to come out and a new ECU + mount fitted (iirc).
    You don't need a new dipstick, just the orange plastic end. IIRC I paid about £8 for a new one. Pull out the dipstick remove the remains of the old plastic, carefully and gently push new plastic end into place ( may help to warm the plastic in some hot water for a few minutes )
    Forget the rear spoiler.......
    ChrisG
    Boost fiend
    Dec 2008
    Swansea
    215
    That's what I thought! Any idea how much the car would have cost back in '99?
    I was dreading that it was an ECU out jobbie to map it. Will look into it in time I think.
    I have ordered a new dipstick tube, remember how much of a pain removing the bits is though when I did it ony A3. Also ordered a we thermostat, as it's not getting up to temp when driving, but is when stopped. Hope that's not too hard of a job.
    As for spoiler, I'm only thinking of a little M3 lip one like Soupie said, not one off an impreza lol
    East Berkshire
    178
    Ours currently has a temp problem as weel only it remains low most of the time! About 6/7 years ago the same symtoms were relieved by a new sender ( top rear of engine near base of screen ) Hope it's the same this time !
    Our total Invoice was , gulp, £29451.70 -- dated 23 July 1999, metallic,Bose,electric roof,sideguard .
    ( we had a CD autochanger added after delivery as well another £400 but at least it had the cable already fitted from the boot to H/U. We have also had rear parking added)
    pm me your email and I'll send you a PDF price list from the time, I'd put it up here but Forum has a limit on size and this PDF is about 3 times the limit !!
    Xenons were £940, Recaros £855, metallic £431,Bose £519
    ChrisG
    "Stick a V8 in it!"
    15,370
    Its an ECU out job, as the chip inside isnt flashable.
    Oct 2011
    West Yorkshire
    67
    Looks very nice, best colour too, saw this one for sale and looked like a bargain.
    Oct 2011
    West Yorkshire
    67
    Oh for the spoiler I would see if an A4 DTM carbon fibre one fits.
  1. My new daily A4 avant
    By dubboy2707 in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th April 2009, 20:42
  2. new s4
    By badbaz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st February 2003, 19:48
  3. Seeing as it's New Year what's your calendar??
    By JohnH in forum General Chat
    Last Post: 10th January 2003, 17:10
  4. This Months Evo new S4 and RS6
    By gabster03 in forum General Chat
    Last Post: 9th January 2003, 21:33
  5. New Blunkpaunt Stereo's
    By Stormcatcher in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2003, 14:32
