Badger5AH Fabrications
Results 1 to 8 of 8
Thread: RTECH Round 2
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,651
    RTECH Round 2
    First trip was getting fueling and other bits running right, now for the fun stuff...
    Starting with 160hp and approx 340nm torque (iirc). Let's see what happens with a live map...
    Mods to date are:
    FMIC
    SS Exhaust and decat
    N249 delete
    Saab yellow injectors
    Sport filter
    SM flywheel
    And of course the RTECH map.
    Results of the day to follow
    Currently rolling in a SKODA!!!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,390
    210hp is my guess.
    Cant see a -029 doing any more than that.
    TD5 Land Rover Defender build
    "Stick a V8 in it!"
    15,390
    You not telling us then? :P
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    I no yeah im waiting for you to post your results up 2 lol !!
    Arrkon's Avatar
    Oct 2010
    1,651
    Not got the result graphs to hand as im at work, but IIRC the ouput was 196hp and 280nm torque. but runs a hell of a lot better, nice progressive throttle map, slightly lowered rev limiter with improved cutoff and some extra fuelling to get some pops and flame spit on overrun.
    Seems the reduced diameter of my FMIC pipes, in comparison to the inlet/FMIC, is causing a pressure drop of around 2-4psi. Starving me of the top end boost.
    Graphs will follow tonight.
    Arrkon's Avatar
    Oct 2010
    1,651
    May 2010
    Bedford
    2,877
    Not too bad. Running 99ron fuel too im guessing? How come you`re running bigger injectors with only the basics done on the standard turbo?
    My results were 199bhp 221ft-lbs with standard intercooler/injectors and then Jetex catback, decat, standard knackered downpipe, TIP, Jetex filter with heatshield, evap/breather pipes removed, forge 007p.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Arrkon's Avatar
    Oct 2010
    1,651
    Quote Originally Posted by Jason.s View Post
    Yep 99RON, the injectors were available so were bought and fitted in preparation to upgrade the turbo, but funds have not allowed this.
    Need to remove the breathers and EVAP myself, and upgrade the diameter of the FMIC hardpipe too.
  1. gt4 - s3 round the nurburg ring
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2005, 10:51
  2. Please give me a round of applause.
    By imported_dukez in forum The Welcome Section
    Last Post: 10th July 2004, 04:48
  3. Rounded one of my locking wheel bolts off
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th June 2004, 14:57
  4. N75J.... Which way round ?
    By nradfo01 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2004, 08:10
  5. WHICH WAS ROUND SHOULD A DV GO?
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2003, 14:41
