EM TuningMonster Motorsport
Results 1 to 12 of 12
    Oct 2009
    190
    Blue/white smoke
    This f**king car is begging to annoy me now.
    Just finished work started the car up fine no problem. Go to pull away on the main road and filled it with blue/white smoke. Hasn't done it since.
    May 2012
    Kings Lynn
    910
    Checked your EGR valve lately? Could be sticking open/closed.
    Current - 2006 B7 A4 S Line Saloon 2.0T TFSI Special Edition, Unicorn stage 1 remap, Metallic Dolphin Grey, 18" TTRS Rotors, Ferrari Red front/rear Calipers, 3.5" Powerflow tailpipes, BOSE, Cupra R splitter, Chrome grille slats, S4 Mirror covers, Black/silver leather interior, Debadged, Arm rest delete, LED plate lights, Dectane LED Red/Crystal tail lights, HID 6k, RS 4 pedals, Rev D D/V, APR snub mount, NGK 7s
    Gone - 2005 B7 A4 Avant 2.0 TDI
    Oct 2009
    190
    Should've mentioned its 1999 1.8t
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    White smoke is normally coolant/oil related and blue tends to be more fuel related ?? possibly just leaky valve stem seals !
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    had it been idling for a long time?
    Could be valve stem seals if so.
    TD5 Land Rover Defender build
    Oct 2009
    190
    Yeah was waiting for a mate to walk out of work too so probably 5-10 minutes, what options do I have to sort the stem seals?
    Cheers jay
    Oct 2009
    190
    Little update/research it hasn't kicked out any smoke since last Saturday been told to check under oil cap while it's running for excess pressure and it has a lot of pressure. Which could hopefully rule out stem seals? And possibly something much easier.
    jcb
    Sep 2005
    uk
    4,077
    Quote Originally Posted by Bradderz_1988 View Post
    really?
    Blue - Oil
    white - Water/Steam
    Black - Fuel (i.e too much of it)
    at least that is what I always went by
    jcb
    Sep 2005
    uk
    4,077
    Quote Originally Posted by steady jay View Post
    I am no AA mechanic but you have to ask yourself where that pressure is coming from?
    usually pressurised header tank and smokey exhaust is an immediate check for head gasket trouble.
    overheated recently, run low on coolant?
    Oct 2009
    190
    Nope not overheated once, coolant is fine too. As it hasn't done it before or after that 1 occasion it's hard to pinpoint so unless it happens again I'm not going to worry too much.
    I'll try to get my hands on vagcom and see if that comes up with anything.
    Aug 2010
    3,138
    Get a sniff test on tge coolant bottle to check for hydracarbons this will be an indication of the head gasket.
    Jun 2010
    warwickshire
    93
    possible slighty worn turbo seals! Happend to my s4 blue/white smoke didnt do it again for a few weeks then 1 completely just gave up this was a bout a year ago and they had done over 100k so due a change any way
  1. Under What Conditions Would A Faulty Turbo Blow Blue/White Smoke?
    By danb986 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th August 2012, 19:00
  2. Blue/White smoke on startup
    By steady jay in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th October 2011, 13:35
  3. '00 2.5tdi clouds of white smoke!!!
    By 0v0 in forum Diesel forum
    Last Post: 18th May 2011, 00:34
  4. White Smoke?
    By vishal in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2006, 13:45
  5. white smoke???
    By ImportRacer in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th May 2004, 02:35
