Sky InsuranceChris Nott
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    revs dying when clutch dipped?
    At last I'm back on the road but have annoying problem. Every time I dip the clutch the revs dip to 250rpm and it hunts like mad. Couple of occassions it's died completely.
    Cleaned MAF out and it's made no difference.
    Ideas?
    Life begins at 140mph
    www.passionford.com
    Jul 2012
    56
    Had a similar problem with my old skyline, changed the MAF and lambda sensor and it cured it
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,369
    could be an airleak?
    I had a similar thing last week after disconnecting the battery though, and it fixed itself after a few miles.
    TD5 Land Rover Defender build
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    Car was fine before coming off the road for a month and I've had a good poke about for an air leak.
    Battery died and a new one was put in at the weekend. Driven about 25 miles today and it's still doing it. Waiting for a mate to call me so we can plug it into VagCom.
    Between this and the front arms I'm thinking I might not bother and just go back to my mountain bike.
    www.passionford.com
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Could be throttle body alignment. I think after a battery disconnect the tb resets to it's base values and takes a few miles of driving to re-adapt but in my experience this doesn't work always and needs a bit of intervention with the old vagcom
    2000 1.8t quattro Sport totally standard (ish)
  1. Belt squeak when clutch is dipped or when air con is on???
    By Cash in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th August 2012, 17:11
  2. Revs limited when in first gear, with clutch down.
    By Gavinpipe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th April 2012, 10:57
  3. Erratic revs / dying
    By Geeman in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th July 2009, 13:54
  4. S3 Facelift Limited Rev Range When Not In Gear Is This Correct??
    By B Panesar in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th February 2009, 21:37
  5. Noise when clutch pedal lightly pressed
    By Obion in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th December 2005, 11:39
