Chris NottAH Fabrications
Results 1 to 17 of 17
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,134
    Coolant temp sensor
    Anyone know if audi have changed the temp sensor on the tqs ordered one and its dark green prt no is 059 919 501 where as mine is blue iirc do i need the blue one ?? Only asking as the outlet on the cyclinder head is leaking coolant slightly so thought id get a new sensor whilst im at it also would you recommend fitting a non-gen oil cooler or is it best to fit a genuine ???
    Cheers in advance.
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    405
    My cts was green iirc. I'll have a check later if you like?
    Aug 2010
    3,134
    Just had a look and its definately got a blue one, going to jump on etka now as i need to get some more part numbers anyway as tge parts guy at work is hopeless lol
    Aug 2010
    3,134
    Had a look and it says blue 4 pin part number - 078 919 501 B Click on it and it says dropped on 01/08/2002 use the part number 059 919 501 which i have, anyone else switched to the green sensor or have you had the blue one ??
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    If my needle is jumping while warming up. Is this the sensor I need to order?
    jcb
    Sep 2005
    uk
    4,077
    IIRC the plug is different isn't it
    I have a brand new green one sitting here that I bought in error!
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Quote Originally Posted by jcb View Post
    different?
    want to post to me as a birthday present :-D
    jcb
    Sep 2005
    uk
    4,077
    Quote Originally Posted by Iceash View Post
    different?
    sure if you cover the £10 postage
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    lol I can get em new cheaper than that!
    Jul 2007
    341
    Not a genuine one. Mine was about £29 inc clip and I ring at the dealers a few months back iirc.
    1999 Audi A4 1.8TQS (Standard)
    2003 VW Golf GT TDi
    2002 Audi S8 4.2 SOLD
    2004 Alfa 156 2.4JTD 20V Veloce SOLD
    2000 Audi A4 2.8 Quattro tiptronic (Electric heated seats, winter pack, lowered on H&R Springs & 18" A8 sport wheels) SOLD
    1999 Audi A4 1.9TDI 110hp (with full Audi Sports kit) SOLD
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Quote Originally Posted by Mr K View Post
    i've used cheapie ones before with success :-)
    Aug 2010
    3,134
    Stick to a genuine sensor !! And you will get a green instead of blue sensor dont worry it supersedes to the green one and is the correct one used on our cars !!Also id say its most probably your stat thats fooked and not the sensor both are around £20 each so do the stat first as they say do it right first time round and only use genuine parts !!
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Well I did wonder stat, changed that 18 months ago, but the needle plummets holds shots up. Holds drops back to zero then returns to where it was then makes it to 90'c. Where is the sensor and stat located? I'll change both for piece of mind.
    Aug 2010
    3,134
    Sensor is on back of the head on the outlet tank, stat is behind the power steering pump follow the bottom rad hose and you'll find it !!
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Do you have to be under car to change it?
    Aug 2010
    3,134
    Id say yes as you have to rest it on its housing and manoeuvre it in to position.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    The new ones are all green.
    If you have a digital clock, you'll have a D Shaped plug and the PN ends in an A.
    If you have analog clock, you'll have a square plug and the PN doesnt have the A.
  1. Help! Where's the Coolant Temp sensor?
    By FactionOne in forum General Chat
    Last Post: 12th April 2006, 09:44
  2. Coolant temp Sensor
    By imported_Tariq in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2006, 12:38
  3. URGENT - COOLANT TEMP SENSOR
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2004, 22:13
  4. V6 coolant temp sensor & idle speed control valve
    By JDA in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2004, 18:27
  5. Coolant Temp Sensor
    By teknobod in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd January 2004, 11:14
