JMB RetrofitsEM Tuning
Results 1 to 8 of 8
    Sep 2012
    Immo chip swap Audi a4 b5
    Hi !
    I'm new to this forum so i hope i posted to the right place.
    Here's my Questsion:
    Which chip on the ecu's motherboard is the immo chip ?
    I found a post in this forum and there's a user who has done this kind of immo chip change before.
    here is the link :
    TQS progress thread, From STD-Scroll-Eliminator.
    My ecu looks pretty much the same, so i assume it's the same chip on my ecu ?
    I would like to remove the immo chip from the old ecu and solder it to the new (used) ecu.
    Read from another forum that it actually works, but there was no picture.
    Thank you !
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,318
    The immo chip is highlighted in this pic:
    http://i38.photobucket.com/albums/e1...100_5494-1.jpg
    TBH its easier just to get yourself vagtacho and code in the new ECU.
    TD5 Land Rover Defender build
    Jan 2011
    Aberdeenshire
    646
    Wot he said.
    (Just don't play with your mates' TT 9999999999999 )
    Removing and refitting chips is possible, but even under the best of circumstances it will thermally stress the silicon, so make it more prone to fail. If you can't get VagTacho, get a 'Man in' for some beer tokens - it will be easier and cheaper in the long run
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Sep 2012
    Thank you for answering !
    At first i planned to order the Vagtacho tool, but then i found out the other way (to solder the old ecus immo chip to the new one).
    Quess i have to go with the vagtacho.
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    VagTACHO is such an easy program to use... you'll be fine
    Currently rolling in a SKODA!!!
    Jul 2012
    Guildford
    97
    With the removal of the chip method is it possible to remove the immobiliser? I am guessing the Audi has the ECU linked to the key fob like a lot of cars but is there a way to transplant the Audi ECU into another car without having to move the entire alarm system (and closkc?) Across?
    Arrkon's Avatar
    Oct 2010
    1,641
    VagTacho... but IIRC you will need the old SKC code
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Has anyone got a link to a reasonably priced vagtacho?
  1. Chipped your Audi?
    By KeepItTidy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd April 2009, 10:28
  2. ECU Swap - Audi S3
    By s3_jon in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2009, 17:42
  3. Having My S3 2007 Chipped at Audi Dealer
    By boothville in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th October 2007, 21:51
  4. Chipping an Audi 1.8T A4 Quattro Sport 1999
    By netwave in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th August 2006, 15:02
  5. Chip from Audi
    By dgannon69 in forum General Chat
    Last Post: 6th August 2005, 23:07
