Volks AutosJMB Retrofits
Results 1 to 7 of 7
    East Berkshire
    178
    battery disconnect ?
    This applies to many Audis but..... about to replace battery in an A4.
    I've read somewhere that if you connect a 12v supply to the ciggy lighter it maintains 12v through the car as that socket is permanently live thereby keeping radio codes, computer etc etc etc happy !
    Is this correct?
    ChrisG
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    The 12v socket is a permanent live.
    I guess could work.
    Not sure 100% my self.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    yeh should work.
    TD5 Land Rover Defender build
    East Berkshire
    178
    I'll let you all know ........
    ChrisG
    "Stick a V8 in it!"
    15,370
    You could also just clip a battery charger onto the battery leads.
    Either way, you'll need to make sure the live lead doesnt touch the bodyshell or any other metal parts around there, or you'll short out your power source.
    East Berkshire
    178
    Yes, I think that was what I did last time -- and wasn't that happy as there is potential for a mishap! Hence the 'plug something in' thoughts...
    ChrisG
    "Stick a V8 in it!"
    15,370
    well the plugged in fag lighter doesnt remove that potential mishap. The live battery cable will still be live, and will still short out the power supply if you touch it against the chassis when powering the car from the fag lighter.
  1. battery disconnected
    By 4wheel in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2012, 22:11
  2. Numerous electrical faults after battery disconnected
    By bigals89 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th November 2011, 15:01
  3. Re-setting ECU After Battery Disconnected?
    By Siena in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th January 2008, 19:06
  4. Replies: 4
    Last Post: 21st January 2006, 17:00
  5. QUICK HELP - Disconnecting Battery...
    By imported_ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th September 2004, 19:41
