Sky InsuranceEM Tuning
Results 1 to 15 of 15
    Aug 2012
    telford
    112
    vcds interface not found?
    i have just recieved my vcds and installed it tried to conect to car and test but comes up saying port status: ok, interface: not found! does anyone have any ideas what this means? any addvice would be helpful thanks
    brasiliangringo's Avatar
    Mar 2010
    496
    Is it genuine or the shareware + ebay lead ?
    Aug 2012
    telford
    112
    shareware + ebay
    Mar 2010
    496
    No idea then could be a variety of issues not least the lead itself.
    Aug 2012
    telford
    112
    is it likely to be a problem with the lead?
    Jan 2011
    Aberdeenshire
    628
    The port config will be wrong.
    Check what port the USB device is on, then change the port number to the VCDS port
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    Aug 2012
    telford
    112
    sorry for being thick but how do i do that?
    Jan 2011
    Aberdeenshire
    628
    You need to go into device manager and hunt for the lead and then look at the settings. One of the settings will have the port number. In the start-up screen for VCDS, the is a test setting of some sort - I forget now - go to the test, and ensure the com port in use is the same as the one in your device manager. Then save the test BEFORE you get excited try and reprogram the toilet flush module.
    I'm assuming your using VCDS lite with the e-bay lead, which does have limited functionality.
    If you are using a pirate copy, this is norty and frowned on here.
    The e-bay leads are a bit of an arse, so you may end up wanting to speak to NHM if it all gets too much, as he will swap you a full CAN lead for the requisite number of beer tokens.
    I think you can still get a KII lead from Ross-Tech in the States, but TBH, the money saved is not really worth it. (I did that though)
    Jun 2012
    148
    as above, will be incorrect com port, I had to do this with mine
    Aug 2012
    telford
    112
    ok ill give it a try thanks muchly
    Aug 2012
    telford
    112
    you were spot on thanks for the help
    Aug 2012
    telford
    112
    it just gets better i have another problem wit it now lol tried scannin for faults it starts then a message comes up saying: a problem caused the program to stop working correctly. windows wil stop the program... any ideas lol?
    Jan 2011
    Aberdeenshire
    628
    No idea on that one. It might be worth re-installing the program - or seeing if there is an anti-virus issue.
    I do refer you back to my post
    Quote Originally Posted by PAULF View Post
    Some members get a bit excited over non-genuine leads, but to be honest, e-bay leads and the shareware VCDS work ok.
    However, if you find your using it a lot - get a genuine one as soon as, and get more options and less hassle.
    Aug 2012
    telford
    112
    ok thanks for all your help
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    Run it as administrator.
    Also, make sure your using VCDS Lite from the Rosstech page, and not the older shareware 409 version that lots of leads ship with, as 409 doesnt work with 64bit windows.
    TD5 Land Rover Defender build
  1. VCDS-Lite not working :(.......
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2010, 22:38
  2. I've not found the A4 convertible comfortable?
    By AudiSport in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st May 2010, 21:42
  3. VCDS reading not matching up with DIS reading!
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2009, 22:05
  4. Replies: 2
    Last Post: 24th July 2009, 14:55
  5. So they've not found the stolen Cupra R...
    By imported_hookie in forum General Chat
    Last Post: 7th June 2005, 20:53
