AH FabricationsSky Insurance
Results 1 to 8 of 8
    Jan 2012
    Malton
    276
    anyone change the tickover using vcds?
    In the FAQ it says
    01-Engine: -- KWP-1281
    VCDS works well with all engines available in the U.S. and most engines that users have tested in overseas markets.
    Idle Speed Adaptation:
    With engine warmed up, at idle:
    [Select]
    [01 engine]
    [Adaptation - 10]
    Enter channel 01
    Enter an adaptation value between 124 and 132
    [Save]
    (May require a Login of 01283 or 11463, depending on year or model)
    VCDS - didnt want to go with channel 01 and when I changed it to channel 02 it seemed to be the tickover setting. First off VCDS didnt want to accept the request but then asked if I was really sure so I cancelled out of it all and scampered to ASN to see what other folks have done.
    Any experiences?
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP
    Administrators's Avatar
    Administrator
    Oxfordshire
    1,000,001,891
    Follow Administrators On Twitter
    This is one of the setting in Lemmiwinks that Revo released years ago. You might still find a copy hanging around on the web.
    Jun 2011
    Great Melton Norfolk
    1,340
    i have seen it on my vcds ,have a customer who wants to change his idle as his van keeps stalling, never tried it yet myself.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,372
    Old vag com could do it, i see no reason VDCS won't.
    I used the exact proceedure on my previous car no problem
    Jan 2011
    Aberdeenshire
    635
    What car are you trying to do it on?
    The 2.5TDi login is different - 26242 is for the AFB engine
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    Jan 2012
    Malton
    276
    It's the 1.9 tdi I just got a cable and downloaded vcds lite. It seems to get into the system fine but doesn't see channel one only channel 2. I'll try and do some screen shots to show what I am trying to describe. I want to slow the idle because it's an auto and what feels like a fast idle causes the clutch to drag more than I like and certainly feels more than the v6.
    Jan 2011
    Aberdeenshire
    635
    You need to log in using the 1.9 codes from the Ross-Tech site, then go into Basic Settings, after logging in.
    However.....
    I don't think you can do it with VCDS lite - although I'm sure somebody will be along to point that out soon enough
    Jan 2011
    Aberdeenshire
    635
    Just to add,
    With most of the Basic Settings groups if you put in a stupidly high value, the system will only set the Max - and vice versa for the lower end of the scale. Handy if you don't know what to start with.
  1. Replies: 8
    Last Post: 17th October 2010, 17:38
  2. Anyone Changed the CV Joint Gaiter?
    By locost47 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th May 2010, 22:02
  3. anyone changed the antiroll bars?
    By imported_kris_tdi in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st June 2006, 18:41
  4. Anyone change the stereo over
    By marriedblonde in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st December 2004, 14:38
  5. Anyone changed the rear speakers in a Bose TTR?
    By clived in forum In-Car Entertainment
    Last Post: 17th April 2003, 23:38
