JMB RetrofitsBadger5
Thread: fault codes?
    Aug 2012
    telford
    211
    fault codes?
    does anyone know what these codes are and what the cause(s) might be?
    17966
    17924
    16514
    18010
    18001
    54
    From the Ross Tech wiki:-
    16514/P0130/000304 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit Possible Causes
    • Oxygen (Lambda) Sensor Heating Bank 1 Sensor 1 faulty
    Possible Solutions
    • Check Oxygen (Lambda) Sensor Heating Bank 1 Sensor 1
    17924/P1516/005398 - Intake Manifold Valve (N156): Open Circuit Possible Causes
    • Wiring from/to Intake Manifold Valve (N156) faulty
    • Intake Manifold Valve (N156) faulty
    Possible Solutions
    • Check/Replace Intake Manifold Valve (N156)
      • Perform Output Test.
      • Use Scope to check Activation Signal while performing an Output Test.
    18001/P1593/005523 - Altitude Adaptation: Signal Out of Tolerance Possible Symptoms
    • Unknown
    Commentary
    This is one of those fault codes where the ECU knows something is amiss, but cannot pinpoint the cause.
    Possible Causes
    • MAF sensor (G70) out of tolerance.
    • Leak in intake system.
    • Throttle position sensors (G187/G188) out of tolerance.
    Possible Solutions
    • Check MAF/replace MAF Sensor (G70).
    • Check intake systems for leaks and repair.
    • Check Throttle position sensors (G187/G188).
    18010/P1602/005634 - Power Supply B+ Terminal 30: Voltage too Low Possible Causes
    • Cables on the Battery were removed
    • Battery weak (voltage)
    • Generator Disfunction
    Possible Solutions
    • Check Battery Cables
    • Check/Replace Battery
    • Check/Replace Generator
    Special Notes
    • If multiple Control Module have Power Supply Faults stored, it's most likely to be one common Problem like the ones shown above. Otherwise when only one or two Control Modules have such Codes stored you better start searching at the individual Power Supply of these Modules.
    • Terminal 30 means unswitched battery power that is supplied even when the ignition is off. This is not referring to any physical terminal numbered 30.
    Jan 2011
    Aberdeenshire
    646
    Clear all codes, then check back after a couple of days to see what is active before diving into 'fixing' stuff
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Aug 2010
    1,540
    Quote Originally Posted by PAULF View Post
    this.^^
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    fault codes?
    Quote Originally Posted by murran View Post
    this.^^
    +1
    Currently rolling in a SKODA!!!
    Aug 2012
    telford
    211
    ok thanks v much everyone
  1. S6 Fault codes
    By bigmoose in forum General Technical / How To
    Last Post: 16th June 2005, 16:16
  2. Help: Fault code 16795
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 17:17
  3. information on fault codes
    By vwjin in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2004, 00:45
  4. Fault Code
    By gman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 16:44
  5. fault code
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2003, 14:05
