EM TuningBadger5
    Lowride's Avatar
    Sep 2003
    Warwickshire
    133
    Why don`t they fit?
    I have a set of 17` rims off an A4 Cabby. I used to run them on my N plate A4 saloon which is 5x112pcd. Why don`t they fit an R plate A4 Avant?
    For some reason they are too close to the control arm to spin round, I did`nt have this problem although they were close. We have tried spacers but no joy
    imported_kris_tdi
    Re: Why don`t they fit?
    did the 2 cars have different suspention?
    Jun 2003
    World of my own
    9,813
    It's the offset (not the PCD) that determines how far out the wheel sits from the hub.
    You must've been lucky on the early car, but the newer A4 must have a slightly different steering/suspension setup.
    Sep 2005
    UK
    11
    i run 8x18s off an a8 (et48) and they are very close to the control arm. My car is a 98 too so it should have the same suspension as your avant. I dont personally see why there should be any difficulty unless the wheels are extremely wide. iirc The std wheels are 45 offset for an a4 so you are spacing the wheel further from the control arm by using 35 offset wheels.
