Results 1 to 11 of 11
Thread: icm delete?
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    icm delete?
    anyone done this? saw a few guides a while ago and skimming through them thought that looks hard and didnt fully understand why they were doing it but since having a few hesitation issues i thought id look into it and it actually seems quite straight forward, its only really moving a wire from icm to the coil, and adding an extra earth
    anyway im starting collecting parts to do it, ive already ordered new push down coils and adapter plates (from 034) but most of the guides suggest buying a new later harness, ($50 ecs) but dont really see the point
    if re-routed the wires going to the icm should reach the coils? so all i'd really need is to chop some plugs and lengths of wire off a later audi? is it any post 2000 model? or even better can you buy the plugs and pins for them new? could someone with etka possibly take a look and see if there listed anywhere
    any tips or advice greatfully received
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,134
    You can get the harness from tps part number is 1JO 971 658 L and its £26 +vat iirc, im currently looking at doing this but im going to find a 12 or 16 way male and female connector of a old wiring loom at work and have it so that it just plugs in and not soldered.
    Heres a few links to ones ive come across.
    My AEB to ATW Harness Conversion with 2.0 GTI ULEV Coils
    http://www.squarewave.com/army/andre...b.97-04-02.pdf
    1998 Volkswagen Passat 1.8T AEB - ICM DELETE DIY
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    You need the new harness as the plugs on the coils are different. The harness gives you all the required plugs, pins, wire etc in a nice easy to order package. You just need to cut and shut it into the wiring loom as neccesary.
    TD5 Land Rover Defender build
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    its the cutting and rejoining bit that bothers me, just wondering if theres a better way by attaching existing wiring to new plugs and pins
    kev
    90 eunos roadster
    "Stick a V8 in it!"
    15,350
    The existing wiring goes to the wrong place though. It goes to the ICM plug, whereas you want to redirect the wires that used to go from the ECU to the ICM streight to the coils.
    I guess you could bridge them at the ICM, but thats messy, better to just splice into the loom at the coil branch and make the connections there.
    I agree with bradderz too, probably better getting a suitable multi-pin connector and using that to make the connections, rather than soldering.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    What does this mod do exactly, what's the benefit?
    Life begins at 140mph
    www.passionford.com
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    I chopped and soldered, Did away with the wires that head towards the ICM altogether.
    Jul 2012
    Guildford
    97
    Quote Originally Posted by Oranoco View Post
    I had no idea either so I googled this;
    AEB to ATW+ Coilpack Conversion (ICM Delete) Project
    Aug 2010
    3,134
    Any joy kev with this yet kev ?? Or have you backed out of hacking that loom lol have your trims arrived yet as i sent them next day on thursday ??
    Well ive orded my spark plugs bkr6e's, i have sourced a suitable 16 way female and male connector through work, basically found one on a old wiring loom but the thought off un-crimping the pins and re-crimping just seemed pointless so, ive ordered a brand new one which they came in pack of 5 still waiting on the male as there on back order have all the female pins and the rest of the male pins are on order as they were out of stock so should see them with the male connector then im going to order the loom and coil packs, just need to speak to a mate of mine to see if he can do me some adaptor plates for the coil packs. (if anyone nows someboy who has a cnc machine word them up see if they can forfill my needs) lol
    I have part numbers for all pins and connectors used so i will probably do a indepth 'how to' for all you non wire friendly felllows lol
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    trims arrived, ordered front ones but on back order 12 days
    icm is now deleted!!
    ended up buying harness but only used plugs and earth looms, removed everything else
    only earth needed soldering
    wiring connector pins to icm can be removed from original plug and fit straight into replacement coil plug connectors once removed from sleeving and routed(they are all same length so just looped them to fit but you could cut to correct length and fit new pins)
    used the earth wire to icm for one set of earth wires, (this was the only soldering req'd) the other grounds on cam cover as original
    the 12v supply wires i removed from original coil connectors and re-pinned them to fit into new connectors
    fitted new bkr6e-11 because i had a spare set (my mx5 uses them) regapped to .9mm and new 2l tfsi coils and 034 plates
    car runs perfect, no hesitation what so ever
    kev
    90 eunos roadster
    "Stick a V8 in it!"
    15,350
    Nice one
  1. A6 for sale *DELETED*
    By delkhela in forum Diesel forum
    Last Post: 25th October 2004, 18:57
  2. ICM = ECM = ECU?
    By in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th September 2004, 05:56
  3. Paint code location needed A.S.A.P? *DELETED*
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2004, 19:34
  4. Thread deleted
    By Administrators in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th January 2003, 13:42
