Volks AutosMonster Motorsport
Results 1 to 8 of 8
    Aug 2012
    6
    cam adjuster rattle
    any1 know if changing passenger side cam adjuster is a diy job?also can you just change the runners and spring without changing the hole adjuster?any1 know where i can get 1 without having my eyes ripped out????cheers
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,904
    you say passenger side, so i assume its a V6?
    Anything can be a DIY job, it just depends on your levels of skill and experience...
    You need to remove the rocker cover (and thus anything in the way of the rocker cover) and you need to remove the inlet camshaft. You will need a special tool to compress the tensioner, which can be had from ebay. I'd probably stick a new chain on while your in there too, as they arent too dear.
    I would suggest you change the whole tensioner, also if its a VVT one you really need to use a proper one, the cheap copies dont always work properly.
    Without more info on the actual car i cant tell you any more.
    TD5 Land Rover Defender build
    Aug 2012
    6
    hi im no mechanic but im alrite with basic stuff,yeah its 2.7tt 99 model,the cars done 130k do you think the rattle will be worn runners or worn spring milage related?i had a audi spiecalist listen to it he said do not worry to much about it and keep driving it but since then the rattle has got louder,im not convinced hes the best mechanic either,you probably know yourself wen you hear a noise on your car it must be fixed, im paranoid incase the chain slips a tooth coz chain will not be under full tension and will not be cheap to fix if it slips,the car drives mint and noise goes away above 1500 rpm,do you think im best off getting the part direct from audi?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    I'd get the top off for a look. These are more prone to bad cams over dodgy tensioners..
    Aug 2012
    6
    ah rite thanks for that .what a i exactly looking for if it is the cam?cheers
    Jul 2012
    Guildford
    96
    I'm concerned about my cams aswell but my car has a constant whine that gets higher picthed with revs but no louder. I cant find any good info on diagnosing cams without the cam cover removed. When I look through the oil filler the cams are always bone dry of oil when the engine is cold. There is oil on them when the engine has just been run. I beleive this is a sign that I am using the wrong oil?
    "Stick a V8 in it!"
    14,904
    Just look a the cam lobes, if they're knackered they'll be all pitted and generally fubar looking. If they're fine they'll be smooth.
    You should be using 5w40 fully synthetic oil.
    I wouldnt expect the cams to be "bone dry" but they wont have big globs of oil on them either, just a light film.
    Aug 2012
    6
    ok mate thanks for your help,i havent had the s4 long im thinking its gona be an expensive car to keep rite .
  1. Cam adjuster seals (may have a different name...)
    By cbass in forum General Technical / How To
    Last Post: 20th September 2004, 20:37
  2. bilstein adjustable platform
    By curtis11 in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st February 2004, 18:02
  3. Headlight height adjustment
    By Gaunty in forum Volkswagen and other VAG
    Last Post: 22nd December 2003, 16:53
  4. Replies: 1
    Last Post: 14th October 2003, 08:02
  5. camber adjustment ?
    By tim in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2003, 16:27
