EM TuningJMB Retrofits
    Aug 2012
    Question New to Audi and Turbos
    Hi everyone sorry if i have posted this in the wrong place. I have an Audi A4 1.8t 1998. I have been reading up on the BOV/DV and was recently given a forge BOV/Recirc valve that is advertised for this car. I went to try and fit it and got myself all confused. Can someone please tell me how to fit this. It is a forge valve with an intake port and an output port (im guessing) with a nipple for a vacuum hose on the top. on the top there is also a dial that turns to open up 4 small holes. When I took the original valve off I couldnt see a vacuum hose that would connect to the top of the Forge. Can someone advise me of where I am going wrong or how to fit it. I have checked the rest of the forum and couldnt see any part that covers my problem. (or maybe I am just a bit of an idiot lol). Thanks in advance
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,642
    Hey Frazer, The vac line is fed from a valve on the underside of the inlet manifold, it runs across the front of the engine in the same clips that the coolant hose sits in... (Red arrow in pic) Failing that, just run a piece of vac line from the nipple on the manifold (green arrow) to the top of the DV.
    Currently rolling in a SKODA!!!
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    Where was the valve you removed?
    I've heard of people removing the pancake oil separator thinking its the dv
    Look on inlet manifold find the vac line near front and follow it across cam belt cover then down towards boost hose, where it ends you will find dv
    Easiest to fit and see it from underneath engine bay
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Arrkon's Avatar
    Oct 2010
    1,642
    Quote Originally Posted by olds_kool View Post
    lol
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Basically they are mounted to the turbo outlet hose under the o/s/f chassis leg, you need to remove the old one and relocate the new one to the turbo intake pipe some are mounted this way (earlier 1.8t's) gives a more audible sound when mounted this way.
    You can just see in this picture where abouts its mounted when its at the intake pipe.
  1. New to Audi and turbos
    By Jason Hastings in forum The Welcome Section
    Last Post: 12th April 2012, 09:25
  2. Ello....New to Audi and New to the site.
    By col004 in forum The Welcome Section
    Last Post: 15th January 2011, 22:27
  3. New to Audi and looking to buy a3 quattro - but petrol or diesel?
    By ds7_uk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th January 2011, 22:37
  4. New Golf supercahrged and turboed 1.4!!
    By Soupie69uk in forum Volkswagen and other VAG
    Last Post: 28th September 2009, 22:08
  5. New to Audi and considering an S3!!!
    By Trigger in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2007, 23:56
