Volks AutosEM Tuning
Results 1 to 20 of 20
    Oct 2009
    190
    Funny noise after fitting induction kit
    I had a new induction kit floating about so stuck it on but straight after it started a fast clicking noise around 10-20 seconds after starting the engine. But if I turn off the heaters in the car it stops.
    Its a 1999 1.8t with aircon
    Any ideas?
    Cheers jay
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,135
    Wheres the ticking noise sound like its coming from maybe the canister solinoid valve (little round brown electrovalve) on top of airbox these can cause a rapid ticking noise but only really heard under the bonnet maybe when your turning heaters on its drowning the ticking out ???
    Oct 2009
    190
    Little update on this its got nothing to do with my induction kit as I've put it back to standard. Had it nearly a week now and discovered 2 ticking noises for different reasons. Oh the joy of buying a cheap facelift a4.
    1: faint tick when I lift off the throttle, coming from turbo side of engine (still have full boost though)
    2: loud tick only when heaters are turned on.
    Any help would be hugely appriciated this car is getting on my tits already.
    Aug 2010
    3,135
    The tick sounds lick the wastegate penny valve mine did this but was only seeing half boost use a stethoscope (how ever you spell it lol) or a pry bar placing it on the turbine side of the turbo and rev the car from the throttle body with your hand as you let off you should here it as clear as day if it is.
    Heres mine totally fubar'd lol
    Oct 2009
    190
    Damn was really hoping it weren't my turbo. Ain't it odd that I've still got full boost?
    Aug 2010
    3,135
    You can have full boost as aragorns did and every other case ive seen or heard of just mine that lost boost and that was the cause of my good hours wasted looking for boost leaks and swapping out parts lol
    It depends on how loose the penny is on the arm mine was clinging on for dear life lol
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Our FWD drove around for ages rattling then fell off eventually. Would only rattle on overrun though. The turbo ive recently removed from the avant was also rattling, and on removal it had a huge groove all round the wastegate penny, and both the rivet that holds it onto the arm was worn as well as the bushing that supports the arm as it passes thru the housing.
    The loud ticking with your heater on is probably either a faulty blower fan or something stuck in the blower fan. Take it out and have a look.
    TD5 Land Rover Defender build
    Oct 2009
    190
    Ah man I have a spare turbo just had a look the penny valve looks ok bit it's got a cracked housing.
    Oct 2009
    190
    Say I have a budget of £6/700 in 2 months what so of turbo upgrade could I get. Ecu has already been flashed
    Aug 2010
    3,135
    Says s3 golf but its actually passat or A4
    k04 turbo kit audi s3 seat leon cupra r audi tt 225 agu mk2 golf ibiza vw 300hp | eBay
    And you wont see 300hp aswel more like 220hp
    Oct 2009
    190
    To be honest I never had any intention of upgrading the turbo on this one but seeing as mine will be dead in a few months I may as well upgrade.
    Oct 2009
    190
    Update on the the noise after turning on climate control, it's defenatly not the motor blower as the noise is coming from what sounds like the sump!!???
    Aug 2010
    3,135
    Have you checked the turbo with a stethoscope also could be the cam chain tensioner.
    Oct 2009
    190
    Sorry mate just had the father in-law find out I'm a absolute tw*t. When I turn it all on and press econ no noise at all.
    "Stick a V8 in it!"
    15,370
    ECON shuts off the AC compressor
    Oct 2009
    190
    So air con compressor is dead probably
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    or belt, or tensioner
    Quote Originally Posted by steady jay View Post
    Oct 2009
    190
    That's not too bad as long I've got some sort of heat pumping through ready for winter. I've got a list the length of my arm, but k04 is at the top to replace my soon to be dead k03
    Aug 2010
    3,135
    One thing is that list wont get any shorter :P
    Oct 2009
    190
    Don't doubt that for a second mate
  1. DV noise after fitting Catch Tank
    By rhubarb4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2011, 17:42
  2. Strange noise after fitting Milltek sport exhaust
    By RGC in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th February 2010, 17:59
  3. Fitting Induction Kit?
    By Ronniebiggs in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th March 2009, 22:10
  4. Slight rattling noise after fitting coilovers
    By Jonezy87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2009, 10:46
  5. just fitted induction kit
    By curtis11 in forum Tuning
    Last Post: 29th December 2004, 17:46
