AH FabricationsSky Insurance
Results 1 to 10 of 10
Thread: ride heights
    Jan 2012
    Malton
    272
    ride heights
    My new (new to me) 2000 Saloon 1.9tdi seems to ride much higher than my 2000 Saloon V6 TDi Q that I just drowned - do the different models come from the factory with different ride heights?
    Jan 2011
    Aberdeenshire
    628
    The short answer is :- yes
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    Jan 2011
    Aberdeenshire
    628
    The long answer is yes, check the suspension PR code.
    It will be :-
    1BA (Standard height quoted in the books 150mm IIRC),
    1BB (+20mm heavy duty. Springs are the same as 1BT, some form of unknown cleverness gave the extra 13mm),
    1BC (special purpose vehicle (God only knows - Thunderbird A4?)),
    1BD (Sports running gear S4), RS4 (Self Evident),
    1BE (Sports running gear, 20mm lowered from standard, as fitted to my saloon, and previously fitted to Mrs PaulFs' Avant),
    1BV(Sports running gear, quattro GmbH - try and buy THOSE!)
    1BQ (Sports running gear, South Africa - I won't make any jokes for fear of being arrested),
    1BT (Heavy Duty running gear - and now fitted to Mrs PaulFs' Avant. +7mm over standard height) and finally
    1BP (trim position as 1BA, but limited bump travel).
    Almost certainly you will have 1BA or 1BE. Check the boot sticker for the codes.
    You may also have knackered/broken springs
    Jan 2012
    Malton
    272
    Thanks Paul - its 1BE the sports lowered on the V6 Q like yours - I guess the 1.9 has the standard ride height. I find the V6 Q more poised and that wouold explain t.
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Most quattros will have 1BE as they're almost all Sport trim.
    Presumably your new car is a FWD, meaning its a boggo spec/SE model rather than a sport model, thus the jacked up ride height and probably flat seats inside too...
    PaulF: 1.8TQS's came with 1BV suspension Its not much different to 1BE.
    TD5 Land Rover Defender build
    Jan 2011
    Aberdeenshire
    628
    Ahh, that explains it! I thought it was their racing stuff.
    Having said that, try and buy standard height springs from Audi. As far as I could find out, you may not be able to!!
    Jan 2012
    Malton
    272
    Yes - disppointingly its the SE spec - I have some time to find the perfect Quattro/V6 Tdi/ Avant combination. And fit it with a snorkel like landrover folk do.
    You could have had my standard springs Paul.....
    Jan 2012
    Malton
    272
    so could I just swap over the springs and shock from the Quattro to the SE?
    Jan 2011
    Aberdeenshire
    628
    Quote Originally Posted by Tom_B View Post
    No, I don't think so.I'm sure the damper mounting points are not the same for the rears, at least.
    You'll probably find the old springs and shocks are a bit tired by now anyway - you'd be much better renewing them if at all possible.
    Last edited by PAULF; 16th August 2012 at 15:06. Reason: Wrong answer given!! (RTFQ)
    Jan 2011
    Aberdeenshire
    628
    .......of course, thinking about it the springs may be the same - I don't know.
  1. standard Vs sport suspension ride height?
    By griffj in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th February 2006, 09:00
  2. S3 Alloys- Price and ride height afterwards? + bonus silly questions
    By keendean in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd December 2005, 10:43
  3. FAO Stuart A3 Turbo ride height
    By s3tle in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th April 2004, 14:52
  4. Ride height
    By h10chy in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st April 2004, 18:00
  5. 1999.5 A4 1.8T - ride height question
    By Kasper in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th February 2004, 10:27
