Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Carl.S
Thread: Anybody on stage 2 Revo?
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,095
    Found their list on the website and they do list a stage 2 upgrade for the B5 150bhp 1.8T? Looks like I just need to source some 225 injectors and then get my local Revo agent to do their thing.
    I'm not expecting miracles but a little more shove would be nice. if I can tipple over the 200bhp mark it would be happy, although I know chasing bhp isn't the bee all and end all.
    Would love to hear from anybody who's done it as to how good it is??
    Life begins at 140mph
    www.passionford.com
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    Aint gonna happen on our ECU's, and definately not if your on an old 557 ECU.
    They'll only cover the newer APU engines with ME7.1.
    If you want a tune, speak to niki at RTech, but i suspect you'll need to change to the later style M3.8 ECU at the very least.
    TD5 Land Rover Defender build
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,095
    Thought APU was on the later B6 A4? To be honest if I can source the later ECU and harness without breaking the bank or losing the DIS then I wouldn't be worried about converting.
    Revo | Applications
    www.passionford.com
    "Stick a V8 in it!"
    15,388
    facelift FWD's have APU's and a few other engine codes that are on ME7.1 and ME7.5, and thus flashable easily.
    Not looked into converting, but i know the early cars use inverse logic for the DIS, which might cause issues. Im sure it would be possible, but you'd need a head for wiring.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,095
    Sounds like a proper ball ache. Thought it was looking a bit hopeful for a minute
    www.passionford.com
    Jun 2008
    194
    Hi There;
    do you know what the part number is on your ECU? (can check by either physically looking or with vag com). is your vehicle drive by wire?
    if so I will happily check if the ECU is flashable or not and if there is a STG2 available for your vehicle
    Best regards
    Carl
    Oranoco likes this.
    "Stick a V8 in it!"
    15,388
    I believe its an OLD cable throttle ECU, its certainly not drive-by-wire, and isnt flashable. Probably an 8D0997557.
    It requires the chip to be changed, and afaik the chips on these really old ECU's are either no longer available, or very difficult to get hold of.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,095
    As aragorn has said it's a very late '96 model A4 with the AEB engine code and throttle cable as opposed to fly by wire. The vehicle is currently operating a Superchip which required the ECU to be cracked open. I am certain that it can't be flashed and will need any program uploading to a chip and then that be installed to the ECU. Will have to double check number but I would say aragorn is likely to be correct with his suggestion.
    If you are able to help extract a bit more grunt from my tank it would be brilliant as the superchip seems very conservative and only raises boost to 12psi (stock TQS levels).
    www.passionford.com
    May 2010
    Bedford
    2,877
    Just go to Rtech tbh. When it comes to the actual chipping and mapping theres not really anyone else i`d consider going to. Mine did 199bhp at 14psi. Only way safely im going to get anymore would be a brand new turbo and binning off the standard sidemount intercooler.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,095
    I see they're in Hinkley so not too bad as I've done Coventry a few times.
    Just dropped them a mail with current spec and will wait to see if they can offer anything
    www.passionford.com
  1. From MTM Stage I to REVO Stage II...Oh my god...
    By hatmeow in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th October 2008, 12:52
  2. REVO stage 2 map for S3?
    By Rabbit222 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th July 2008, 13:14
  3. Revo Stage 2 - S3 -
    By jm-baker in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2008, 10:00
  4. Revo Stage 2
    By benlelay in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2007, 13:46
  5. Now have Revo stage 1 for 1.8T !
    By JB_A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2007, 08:44
