Chris NottEM Tuning
Results 1 to 11 of 11
Thread: My Gearbox
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    My Gearbox
    Hi Guys,
    I’ve noticed if I sit in 2nd gear around the 3k mk, I get a very slight whine. Not the grinding sound of failed bearings so I believe anyway. I’ve had them fail on the input shaft before and that’s a racket!
    so I’m wondering if others with the 1.8t engines notice there gear whine slightly?
    If accelerating the engine drowns it out lol it’s only while holding at the 3k rev mk as such.
    Thanks,
    Ash
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    yeh i notice it at times on mine too.
    It also makes a horrible noise if you apply a sideways force to the shifter in the lower gears, ie if your in 2nd, and pull the stick towards fourth.
    TD5 Land Rover Defender build
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    So just crappy gearbox's then rather than a fault? Syncomesh being noisy at a guess? I'll try the moving the stick round and let you know what i find
    "Stick a V8 in it!"
    14,900
    mine started whining after the oil level got low, and then has continued doing it after it was filled back up, so i guess i've slightly damaged one of the bearings with the low oil level...
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Mines not Lost oil. But I've heard the second gear hub is a bit crap. Well as long as it doesn't damage the shaft it's not a big deal :-)
    "Stick a V8 in it!"
    14,900
    have you checked the oil level?
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    yep :-) even changed it recently for the hell of it level always been fine :-)
    "Stick a V8 in it!"
    14,900
    Cool, mine had no real noticable leaks bar a slight weep from the selector shaft seal.
    Took a litre of oil though!
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    bloody hell! So would you bother changing the box?
    "Stick a V8 in it!"
    14,900
    i've got myself a 6 speed to fit to mine, but otherwise i'd just be ignoring.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Ooooh I want 6 speed! Easy to do?
  1. changing the gearbox oil
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2003, 06:14
  2. S3 Gearbox Oil for ridding Notchiness
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2003, 22:24
  3. Sequential Gearbox Anyone?
    By AL_B in forum General Technical / How To
    Last Post: 21st February 2003, 12:58
  4. Gearbox Repaired!
    By Joshie in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2003, 08:59
  5. DSG auto gearbox... confirmed?
    By jamesa in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th January 2003, 14:21
