JMB RetrofitsVolks Autos
Thread: AC Gone pop?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,971
    AC Gone pop?
    For the last couple of days I've had the smell of AC oil in my cabin on start up but still pumping out cold air, I was waiting for it to go pop and it went to day.
    I just had to go when its pushing 30 degrees and sunny.
    Now all I'm getting is hot air and no oil smell.
    I replaced the compressor and dryer unit bout a year ago.
    The Compressor was 2nd hand so it could be that but I'm trying to work out what could have gone pop to cause the Oil smell to leak in to the cabin and then pump out hot air.
    I stripped the heater unit out at Easter to replace the heater matrix.
    I'm about to pop out to check pipes and connections.
    Any one got any ideas?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,325
    Not sure how you could get AC oil in the cabin. If the evaporator was leaking it'd dump refrigerant into the cabin as well, and if it did that you'd know about it!
    I'm gettin a man out tomorrow morning to regas the AC on the avant, to hopefully make it work properly again.
    The first thing they do is a leak check, so maybe it'd be worthwhile for you to do the same.
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,971
    That's my thinking.
    But the evaporator is the only unit that passes in to the cabin and could leak oil. Like you said, if it was leaking I'd notice the gas as well as the oil and the noise of gas leaking.
    Unless the pipes as some how came loose?
    Also, why would it just be pumping out hot air and not cold air?
    Then again, that could be because of the current out side temperature and not cooling the air down enough.
    ahhhhhhhhhhhhhhhhh
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,971
    I've set my self up for it being the evap, if its any thing else then happy days.
    If it is the evap I got to strip the bloody dash out again.
    Twice in 1 year. damn it!!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,971
    Went to the AC people on Monday, got it re-gassed and tested.
    All seemed fine for a day and then it stopped again.
    Went back to the AC guy today to look for some AC dye to help us find the leak.
    Found a section of green dye around the drain hole in the transmission tunnel.
    It appears to be the evaporator at fault.
    Not news that I wanted at all.
    Another job that requires the dash to come out and a bit of coolant draining.
    Any one ever replaced a evaporator on their B5?
    I've done the heater matrix but not this.
  1. 2.0 Tdi Turbo gone POP!!
    By rosscotdi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th July 2009, 18:27
  2. Coil Pack gone ???
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st November 2003, 10:15
  3. Rattle on acceleration, occasional exhaust pop.
    By benk in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2003, 09:46
  4. where have the forums gone?
    By sfource in forum General Chat
    Last Post: 21st June 2003, 19:16
  5. NIP loophole gone?
    By bird in forum General Chat
    Last Post: 5th June 2003, 14:17
