Volks AutosMonster Motorsport
Results 1 to 8 of 8
Thread: Rolling radius
    Oct 2008
    Glasgow
    430
    Rolling radius
    I am considering fitting a new set of new wheels to my rs4. The fronts are 8" wide the rears 9" wide. Will i have issues if i run 215/35/19 on the front and rear? I am happy to run a stretch on the rears in an attempt to keep the rolling radius the same.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    215's are surely far too narrow?
    Especially on an RS, they run 255's as standard?
    running the same tyres front and rear is fine, but 215's is just going to look silly on a RS.
    245/30r19 or 255/30r19 might be a shout?
    TD5 Land Rover Defender build
    Oct 2008
    Glasgow
    430
    I think they will be to narrow, but i was using that size as an example as those are the size of the tyres currently fitted to the wheels.
    I think that might be a good shout, so there doesnt have to be to big a size difference to keep the rolling radius in check?
    "Stick a V8 in it!"
    14,907
    the rim width doesnt effect the radius a huge amount, so as long as the tyres are the same size front and rear i recon it'll be fine.
    Aug 2010
    1,540
    when going up or down in wheel size.... its the profile/aspect ratio that you change to keep the rolling radius the same or similar. not so much the width, but it can be juggled around within reason to get near the original rolling radius.
    205 55 r16
    the 55 is a percentage of the width. 55% of 205.
    always go a little under the original rolling radius rather than over. nothing wrong with your speedo under reading, but over reading can be a problem for obvious reasons.
    Oct 2008
    Glasgow
    430
    Is there something like a calculator that can work this out? It would make getting the correct tyre size easier
    "Stick a V8 in it!"
    14,907
    Googling "tyre calculator" finds a few options.
    I've used this one before:
    Tire size calculator
    Oct 2008
    Glasgow
    430
    Thanks, I will give that a try.
  1. 19" wheels rolling radius
    By nicks3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th August 2009, 12:59
  2. rolling radius help!
    By CJA318T in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2007, 09:28
  3. rolling radius.... yes i'm bored
    By dummi in forum General Technical / How To
    Last Post: 7th May 2006, 22:53
  4. S3 Anti-roll bars
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2004, 00:05
  5. OETTINGER RULES - Got My Car Dynoed (Rolling Road)
    By XXX_18T in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2003, 09:56
