Volks AutosEM Tuning
Results 1 to 9 of 9
Thread: No power
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    No power
    My car has just developed a fault where when i plant my foot down it goes no where. The car is nolonger boosting somtimes it will start to then back right off again and the car wont pick up speed unless i go down a hill...
    Any ideas i thought it could be the N75 valve so i changed this for my mates N75j to test and that still did the same and now it feels even worse than before please help!!!
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,742
    Re: No power
    I have a problem like that.
    Try unplugging the MAF and see if it changes the car a little.
    Its the big plug btw with the big rubber cover. I am sure you would know anyway.
    Let me know how you get on.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Re: No power
    I had that changed last year so i hope thats not the problem.
    madkebab's Avatar
    Dec 2003
    South West
    396
    Re: No power
    Check all your hoses mate. With your setup if your still on the oem hoses you could well have split one. Have you got a boost gauge? If not I recommend getting one, makes it easier to diagnose this sort of problem.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Re: No power
    There are not split hoses as they are all new.
    Its weird as it boosts then backs off every now and then.
    imported_VaulterTim
    Re: No power
    DV?? Is it diaphragm or piston? Limp mode maybe? Doubt that though if you haven't changed anything... hmmm [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Re: No power
    Its not the DV either as that is a new piston one, but driving home today it was slightly more powerfull and was going faster but not as quick as normal.
    Sep 2005
    Bucks, UK
    27
    Re: No power
    had similar problems on my S3, fault turned out to be faulty throttle potentiometer and a lambda probe. Its not impossible that another MAF could have gone though.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Re: No power
    true best get it booked into a garage and let them sort it out.
