Results 1 to 11 of 11
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    quattro rear wheel bearing cost
    how much do you think it should roughly cost to fit rear wheels bearing to 2.8 quattro?.... ive just been quoted £360 for the pair, which to me possibly seems a bit steep.
    how hard are they to change? i do have access to a press as i know they have to be pressed in/out, but just wasnt sure if i had time but at that price i might make time.
    boost-addict's Avatar
    Aug 2011
    977
    tere no harder then a fwd car being that its a drive shaft on the rear. i havent done one on my a4 yet but to be honest it cant be hard. no special tools would be needed, as for pressing beairngs i would pursume thats not needed its only a wheel bearing.
    so cant help more but my reply is better then none
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,374
    2-3 hours to strip it and similar to go back together. Then time for pressing.
    I think the bearings are 40odd quid each for decent ones, dont buy crappy ones, or you'll be doing the job again.
    TD5 Land Rover Defender build
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    The rear bearings on a quattro in terms of design are almost identical to the fronts of a FWD, so you most definitely do need access to a hydraulic press to fit them, when I did the fronts on my FWD it took approaching 5 tons of pressure to get the bearings in/out.
    As Aragorn has said , do not buy cheap bearings or you will be doing the job again very soon.
    I made the mistake of buying 'German' OE-quality bearings (supposedly Febi-Bilstein but now I wonder.....) from Ebay that lasted about 10 months/12k miles before becoming very noisy again.
    I then fitted 2 x Genuine ones (interestingly 1 was German FAG and the other an Italian SKG one) and they have been perfect for the last 18 months/ 15k miles......
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    ah stuff it ill do it myself then and save some money.
    where the best place to sourse the bearings, and i guess ill need to have the wheel alignment redone after.
    these bearings have had a bit of work though , im the 2nd owener and ive had the car 7 years and ive never had them swapped before and theres nothing in the full history from previous owner to say they had been done and the car has now done 131,000 miles so thats pretty good lol
    Jan 2011
    Aberdeenshire
    646
    As everybody has said, get good ones.
    I've just changed three of the four bearings on her Avant at least twice over the last 15,000 miles or so.
    I now have FAG bearings from All German Parts at about £30-£40 each for the back ones, so don't expect any more problems.
    If you can access a press, it's not a bad job. Some clues are here How to replace front and rear suspension parts (with pics) although the rear pics are a bit limited - I have more to add but am busy!!
    You basically undo the driveshaft bolt, jack up the car, remove the brake caliper and disc (you can remove them together), unbolt the rear arm drop link (use a spanner to hold it against the nut), and the rear arm (good luck with it not spinning on removal or refit) unbolt the top arm, undo the eccentric bolt, AFTER marking it's position (then wish you had bought a new one,as it's buggered, along with the bush), lift up the rear seat and disconnect the ABS sensor plug, feed it through the floorpan, undo the lead cover on the wishbone, remove the hub and change the bearing.
    Refit is the reverse of removal, remembering the driveshaft bolt needs replacing and is a good 5 white knuckles on a 3ft scaffold tube! (IIRC 70lb/ft then 180 degrees turn - check). Ideally you will get a 4 wheel alignment done afterwards.
    Something like the above, anyway
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    617
    I bought my Genuine bearings from an obsolete VW Audi Skoda stock specialist on Ebay (again!) and they cost just £20 each as they were listed only as VW Passat Syncro rear bearings , luckily the brilliant ETKA on my PC unearthed the fact that the identical bearing was fitted to the front of my A4 too!.........
    As I had bought a hydraulic press to do the job 1st time around (much like your predicament 205man it was cheaper to buy a press and 2 bearings than to get a garage to do it), it wasn't too much of a hardship to do the job a 2nd time......
    "Stick a V8 in it!"
    15,374
    FWIW the one that i had that failed was also FEBI...
    I'd be avoiding those in future.
    SKF or FAG are decent, as are Timken, INA and a few others.
    The front bearings on the missus car are Meyle branded and they seem to have lasted ok so far.
    Jun 2011
    73
    Definately go for fag German bearings GSF around £35-£40 - I did all 4 bearings on my 1.8T sport quattro, but bought my own wheel bearing removal and installation kit off ebay for £86, its worth its weight in gold, you will never get them out unless you have the right tools like most other things, it can also be used for other bushes,but it did save me masses on labour charges, they did take a bit of getting out though as they were original I presume, once I had done one and realised what was involved the others were relatively straight forward - not for the faint hearted though, there are some decent videos on you tube that I watched which were really helpfull.
    Aug 2011
    977
    "touch wood" mine sound and feel fine so be glad not to do them while i do the car but if it does then ill be doing it my self
    spartacus68's Avatar
    Jan 2012
    Aberdeenshire
    56
    I fitted a FAG rear bearing. Labour cost: £182, but that included new camber bolt, adjustment and alignment check.
    Is that with or without VAT?
    2001 B5 A4 2.5 TDI Avant quattro sport (155k)
    2003 A2 1.4 TDI SE (125k)
    1995 80 TDI SE Avant (175k) sold
  1. Quattro rear wheel bearing
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th October 2010, 21:39
  2. a4 2.5tdi quattro rear wheel bearing
    By willieigs in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st July 2009, 09:14
  3. interior mats/rear wheel bearing
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th March 2009, 20:14
  4. Replacing rear wheel bearing
    By Leon in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2009, 14:47
  5. Rear Wheel Bearings on an 8L S3
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2008, 18:48
