Results 1 to 7 of 7
    imported_ZeroK66
    Cleaning MAF...?
    Hello all,
    My 2.8q 30v has nearly 95k on the clock and feels a lil hesitant at times and as it is fitted with a K&N filter - I wonder if it would be worth cleaning the MAF.
    How do I do this without breaking it?
    imported_VaulterTim
    Re: Cleaning MAF...?
    Isopropanol spray is the best... you can get it from places like Tandy, RS, that sort of thing. Unsure of cost.
    Do a search on here for more info, it's been covered quite a bit.
    T
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    Lots of threads on Audiworld on this, do a search and you will find a couple of in depth articles, none from memory were very successful.
    Did see another thing recently on this pointing to a bad contact between the MAF and connecting plug. Apparently a dirty contact at this point can give similar problems, makessense really. Advise is to give this a clean with electric contact cleaner. Let us know how you get on.
    imported_ZeroK66
    Right... so I have done it...
    Took the first plastic cover off the air cleaner area and you can see the lug plugged into the MAF.
    I unplugged this, and went to un-screw the MAF. Bugger... the screws used require a special tool. I got hold of a set of pliers - grabbed the head of the screw and loosened it this way - came off easy enough.
    I left the sensor part of the MAF submerged in 98% alcohol for about 20 mins and then a few mins out to dry.
    Popped it back in, plugged it in, turned the key and hey presto... it started. Been driving it for a few days and it seems smoother. I used to have a flat spot around 3500-4500RPM which now seems to be cleared. See how the economy goes.
    Cheers,
    Sep 2003
    medway,kent uk
    103
    has anyone a picture of a maf on a w reg 2000 1.8t as am unsure quite where mine is, i think it might be inside the airbox
    imported_ZeroK66
    It should be on the pipe between the airbox and the inlet manifold... probably the only thing that has wires going to it on that pipe.
    imported_VaulterTim
    It's IN the airbox... take off the top and you will see it mounted in there. Inside a plastic cylindrical housing.
